How do pull up and pull down resistors remove electrical noise?
Pull-up and pull-down resistors are essential in digital circuits to ensure that input pins on microcontrollers like Arduino have a defined logic level, either high or low, preventing them from floating and picking up random voltages. This is particularly important for CMOS inputs, which are high impedance and can be influenced by static charge or electromagnetic interference, leading to unpredictable behavior. The resistors create a stable connection to the power supply or ground, effectively eliminating the uncertainty associated with unconnected inputs. While some microcontrollers have internal pull-ups that can be enabled, external resistors are often recommended for guaranteed performance. Proper use of these resistors is considered good design practice in electronics to maintain reliable signal integrity.
kolleamm
I’m doing a project with my Arduino, and I’ve seen some tutorials on YouTube explaining how to use pull up or pull down resistors to make the input values on the board reliable, basically either a 0 or a 1 without any random changes from other em sources.
The only thing is I still don’t understand why it works. The videos explain how to create the circuit but not so much the theory behind it.
Any help is appreciated.
IC inputs have some inherent capacitance. The pull-up resistors will make a low pass filter between the power supply (a source of noise) and the input. They also limit the current that can flow during transients in more extreme cases.
There are a few other reasons pull-up resistors are good. I'm sure others will chime in soon to describe those.
From what I’m understanding the input cable is like an antenna, and the resistor essentially reduces its size?
What input cable? You didn't say anything about distance transmission, antennas, cables, etc.
That opens up a whole set of additional reasons to put a resistor there which are a bit more complex. Guidance will depend on a good description of the set up for that. So my only comment is that signals that travel over significant distance (significant depends on the frequencies, rise/fall times etc.) benefit from proper transmission line termination (impedance matching etc.). Most good designs will have circuits/ICs dedicated to just transmitting or receiving signals over distance.
In normal engineering speak, pull-up resistors are mostly confined to local PCB layout sort of considerations.
no, not correct
using pull-up or pull-down resistors assigns a fixed value to the pin(s) usually +5V or +12V for up and 0V for down
this stops the random voltages from appearing on the pin as noise when the pin(s) is/are left floating
Likes scottdave and phinds
davenn said:
no, not correct
Yes! Don't leave pins disconnected (like if you have a switch that might be open). I was assuming the question was about a pull-up resistor vs. direct connection to a power supply.
Also, for many uControllers pull-up resistors may be internal and programmable, then, if you set it up right you don't need anything external; but the concept is the same. One way or another @davenn is absolutely correct, logic inputs should have a defined value in the circuit.
The truth is the various reasons for pull-ups and such can be pretty complex. This is where you will want to just default to "good design practice". Use pull-up resistors unless you know you don't need them.
Likes davenn
The old TTL technology may not have needed default pullup/pulldown resistors, but CMOS logic certainly does. There are two fundamental issues -- First, the CMOS inputs are very high impedance, so if they are left open, they can float high or low depending on static charge or even loosely coupled EM fields like AC Mains noise on nearby conductors. I once made a neat little LED 8-bit monitor circuit that could probe 8 logic signals and show me their state on the LEDs. I learned quickly that any unconnected inputs could show high or low based on my hand coming close to those inputs (static charge and AC Mains noise). Lesson learned.
Second, if CMOS inputs are floating near their mid-input voltage (say around 2.5V for a 5V CMOS input), the whole logic gate circuit can go into the linear region for the transistors, and conduct significant current from the power rail to ground. Typically it won't be enough current to hurt the logic, but it will put you well above your Icc budget for the circuit.
https://upload.wikimedia.org/wikipe...MOS_inverter.svg/1200px-CMOS_inverter.svg.png
As others have noted, an input "cable" changes things a bit, since it presents a stronger signal to the logic input, versus an on-PCBA logic signal. Please clarify. Thank you.
Be careful in this -- some uCs tri-state their inputs when they are in reset, so the on-chip pullups may go away during resets and the built-in-self-test period. If the levels need to be guaranteed, use external pullups.
Likes alan123hk, davenn and DaveE
There’s no antenna, that’s just me trying to make sense of the circuit.
I just want to read a reliable digital value with my Arduino, and want to know how pull up or pull down resistors help me accomplish this.
My overall goal is to be able to control a mosfet transistor without any interference in the circuit.
davenn said:
no, not correct
Yes but how
kolleamm said:
Yes but how
In logic circuits, the input voltage should be at logic 1 or logic 0, depending on the exact configuration. If left unconnected, the input can vary above and below the switching threshholds causing the output to vary at random. The pull-up (or pull-down) resistor ensures that the input is in a known steady state
https://www.electronics-tutorials.ws/logic/pull-up-resistor.html
Likes DaveE
kolleamm said:
Yes but how
The post I told you how, what part didnt you understand ? :smile:
If the input pin has very low capacitance and does not sink or provide current then even a small amount of charge (from noise) might effect the sensed logic level.
With the additional resistor these random charges are transferred to ground or rail: you need far more charge (than just noise) to set the logic level.
So does the resistor merely filter out the noise with its resistance or is it part of another circuit that the noise gets sent to?
Stop thinking about noise, it's nothing to do with noise.
Look at your first circuit: when the switch is open a very small current flows from the +5V rail via the pull-up resistor to the input pin, which signals HI. When the switch is closed a very small current flows from the input pin via the switch to ground and so the input pin signals LO.
If the pull-up wasn't there and the switch was open then the input pin still has to signal either HI or LO, but who can tell which it is going to be? If there is a leakage current to ground then maybe it will be LO, or maybe there is some square wave clock signal PCB trace passing close which induces a current in and out of the pin which oscillates from HI to LO (OK, noise may be something to do with it) - the point is that if you leave it floating you have no guarantee whether it will be HI or LO.
Isn’t the input pin a positive pin? So shouldn’t it flow towards the board’s ground pin? (For HI)
No, that would make it an output.
Another way to look at it: take away the resistors from both of the circuits in your OP so all that's left is the switches and the MCUs. When the switches are closed, the first input reads LO and the second input reads HI. When you open the switches, the circuits in the two diagrams are electrically identical; how does the one on the left know that you want it to read HI and the one on the right LO?
Starting to run out of suitable 'another way' angles...
Well, noise is a weak signal. If there is nothing else the it may be able to determine the logic state of the input pin.
The pullup (or pulldown) is a ... signal. Not really strong (if carefully selected) but far stronger than the expected noise, so it can dominate the logic state of the input pin against the noise.
The signal you want to sense is a strong one: it can (it should) override the pullup (/pulldown) so if there is signal you will 'see' the signal.
... and that's my bottom line o0)
Likes berkeman
What if the only thing connected to the input pin is a loose wire, is it still possible for the controller to pickup the noise?
Did you understand my post #7?
It would experience more noise?
No.
No.
So what your saying is that unconnected inputs can experience those fluctuations.
I’m still confused as to how the resistors then solve this problem if they merely act as a filter at a part of the circuit.
They are not a filter. Please un-learn that concept.
The resistors provide a medium-impedance tie to one of the rails, ensuring that the input voltage is well defined. The input impedance of CMOS logic inputs is in the MegOhms, so attaching a 10kOhm pullup/pulldown resistor easily defines the input voltage.
You just need to ensure that whatever your external drive circuit is can overpower the pullup/pulldown resistor to assert the other logic level. You would not use a 10 Ohm pullup resistor, for example, because it would be very hard for a connected logic output to fight that pullup and pull the input pin below Vil to cause a logic low input.
Does that make sense? Can you link a couple of CMOS logic gate datasheets that you've been reading to learn about input Vil and Vih specs and Vol and Voh specs? Thanks.
Likes .Scott, DaveE and pbuk
Can you elaborate more on the medium impedance tie and what exactly you mean by tie. Are you saying it ties another circuit or that it acts as a bridge?
It simply means a connection. In the first circuit it ties the pin to 5V (or 'pulls the pin up') and in the second it ties the pin to ground (or 'pulls the pin down').
In your first circuit with the switch closed there is a connection to ground, so the pin reads 0. Open the switch and there is a connection via the resistor to 5V (the current the pin draws is tiny so we can ignore the voltage drop across the resistor) so the pin reads 1. In your second circuit with the switch closed there is a connection to 5V, so the pin reads 1. Open the switch and there is a connection via the resistor to ground so the pin reads 0.
Now take away the resistors.
In your first circuit with the switch closed there is a connection to ground, so the pin reads 0. Open the switch and there is no connection to anything so the pin is 'left floating' and doesn't know what to read. In your second circuit with the switch closed there is a connection to 5V, so the pin reads 1. Open the switch and there is no connection to anything so the pin is in exactly the same condition as in the first circuit: it is 'left floating' and doesn't know what to read.
Likes DaveE
OK - are you familiar with a "thought experiment"... In the diagram showing the input circuit, you see two MOS transistors, their input gate is insulated, and acts like a small capacitor.
So step back and think of only a small (and very good - low leakage) capacitor, one side of it grounded.
Tell me what the voltage across the capacitor is?
You can not - depending on what it is connected to even static may impact the voltage, it is not defined.
Now apply a 5V signal, and then remove it... the 5V may remain on the gate for an unknown period of time.
Now - attach a 10K resistor across the capacitor... NOW what is the voltage on the cap? Unless it is connected to a signal with enough current to keep a voltage on a 10K resistor , the voltage on the cap will go to or drain to zero volts, and be held there.
Yes - this is clearly not ideal, we have added a load to the incoming signal, but the effectiveness of the input on the uC is good enough that we live with these issues.
That's a bit too simplistic. MOS circuits have a very high input impedance and they have very high voltage gain all internal signal paths are coupled to each other. If the logic technology can handle thousands of MHz signals then an input can admit that sort of bandwidth of noise or interference and, hence, significant levels signal. Even a short length of internal connecting lead can act as a significantly long 2GHz antenna or coupler, not to be dismissed as zero length when it's right next to another lead carrying signals. You have to ask what value could you find on a floating or uncommitted input pin (perhaps right on the threshold level). A random induced interference spike, appearing on a floating input can take the level high or low. A pull up/down resistor of a low enough value will reduce any induced voltage to something well below a logic level. Coupling can also occur on power supply rails, of course. If the logic technology can handle thousands of MHz signals then an input can admit that sort of bandwidth of noise and, hence, significant levels of brief voltage spikes.
This has always been a problem, even with early logic designs (5MHz clock speeds) and we take it as read that we define every input level in a design - even in unused elements in an integrated circuit.
In general, I do agree.
In this particular topic, I feel like it's still not simple enough...
Likes sophiecentaur
Basically it's like this. Imagine that instead of your MCU, it was a voltmeter that was connected between your MCU pin and ground (basically for all intents and purposes, is how a logic input would operate), and on the other side of the voltmeter is another circuit (which would be the rest of the internal MCU circuitry).
Now let's say you designed your program to recognize the switch's CLOSE position with a logic of 0 (in which case, our voltmeter should read 0V). When you let go of the switch (I'll assume this is a simple switch, and not a detented/holding type), how do we make sure that our voltmeter reading registers +5V (switch's OPEN position) at the moment of open circuit, without being affected by the goings on in the other circuit (internal MCU circuitry)?
The reliable answer would be by connecting a pull-up resistor from pin to +5V, in order to ensure that our voltmeter reading is as close to +5V as possible, as soon as possible, as reliably as possible, and force the MCU to acknowledge ASAP that we have opened the switch, and for good. Pull-up resistor value should be significantly large, as we are not trying to pass current, and should therefore minimize voltage drop.
Same narrative with the pull-down resistor for forcing MCU to acknowledge logic 0 (voltmeter reading of 0V) if you want it to recognize logic 0 = switch OPEN.
Likes sophiecentaur
  • #31
Too much simplicity can give the wrong lesson though, although I can see I wrote rather a lot. :wink:
Fact is that circuit theory is actually complicated and you can't safely take short cuts.
Likes Rive
  • #32
Yes @berkeman is right, you should ignore noise and filtering for now.
I'm afraid I mislead you with my earlier post where I mentioned filtering in response to your "noise" related question. I was thinking of different, and frankly, uncommon noise problems in logic circuits. It's not that there is no filtering or noise issues, but they are subtle and rarely an issue in normal environments.
It sounds like your issue is inputs that might have an undefined digital input because the circuit connected doesn't force a valid digital 1 or 0 level.
The image below is part of the datasheet for a common CMOS IC. Consider the Vih and Vil specs. These define when the device will interpret your input voltage as a logic high (Vih) or logic low (Vil). Your device will also have a datasheet like this, although you may need to search a bit to find it.
What they are telling you here is that if you want the input to be read as high you must provide a voltage greater than the minimum value of Vih (>3.15V when operated from a 4.5V power supply). If you want the input to be read as low you must provide a voltage less than the maximum value of Vil (<1.35V when operated from a 4.5V power supply). As your input changes levels the device will switch at some voltage between these two guaranteed levels. So for reliable operation, you need to avoid an input voltage in the middle of this range. An input which is disconnected (like an open switch, for example) could be at any voltage. Avoid that.
edit: Some other logic families may also give you a specification for the current required by your circuit to drive the input high or low. These are normally called Iih (the current into get the input high) and Iil (the current out to get the input low). They don't have that for these simple CMOS inputs because the current is really small (typically 0) and in either direction, so, instead, you'll find an input leakage current spec somewhere else in this data sheet which may look like ±1μA, or something similar.
  • #33
This link https://NDAcademy.FoxPing.com/ => Electronics is Easy? => 5.1 Digital Component Basics --- and 3.5 FETs (Field Effect Transistors) --- describe the role of pull-up and pull-down resistors.
  • #34
If you are including interference and crosstalk in that comment then it's very common when using a technology at its maximum. An unterminated input pin can attain a level that takes it 'either way'. Why take the risk? Just give it a defined level.
  • #35
This is very correct and important, the following is a real example of my own experience.
I used to work in a company that designed and produced electronic quartz watches. If we received thousands of microcontroller mask chips, and then discovered that the software engineer had forgotten to use a resistor to connect one of the microcontroller’s input ports to power or ground, it would have disastrous consequences for the company, not only financial loss, but also unable to deliver the goods to the customer on time.
The current consumption of the watch is just about one 1.5uA, for a 20mAh coin cell battery, the battery life is around 20/0.002 = 1.5 years, as long as there is one CMOS input port of the microcontroller floating, the consumption current may jump from 1.5uA to 5uA, this will greatly reduce the battery life from 1.5 years to less than half a year.
Even if it does not affect all other functions of the watch, no one will buy a watch with a battery life of less than half a year. 😢
Likes sophiecentaur
  • #36
Sorry, the expression here may be unclear. Of course, software engineers do not need to add real resistors to the circuit. They only need to use software instructions to enable the pull-up or pull-down resistor inside the microcontroller.
  • #37
I'm not aware of any pull-up resistors and pull-down resistors inside a microcontroller. Pull-up resistors and pull-down resistors are attached as part of the electronic hardware design. There are no switches to enable / disable them (switches would add cost and consume real estate). See for info about pull-up and pull-down resistors.
  • #39
I've designed electronics and written code for microprocessors and microcontroller for more than 40 years (Texas Instruments, 3M, Emerson). I'm curious, which microcontroller has internal pull-ups and pull-downs? Thanks!
  • #40
Thinking more about this, when pull-ups and pull-downs are attached to the electronics, they are active immediately when power is applied. Waiting for a micro to enable them is too late.
  • #41
Yep. Some do that. You can look into the PxREN configuration in MSP430s for example (there are others too).
Skip ahead to about 8:20 in this video:
https://training.ti.com/msp430-workshop-series-3-12-using-mspware-gpio
  • #42
It's a common solution when the uC has configurable GPIO pins (which can serve as various type of input or output pins depending on the configuration).
The EE still has to ensure that things does not go haywire while they are not configured (during startup, reset, SW error and so on).
Likes alan123hk and DaveE
  • #43
I know some PIC ucontrollers have pull-ups. 18F2520 for instance has pull-ups on one set of ports. Download the data for it if you wish to see.
  • #44
I like to think of the pull-up and pull-downs as changing the load impedance in a resistor divider. Here is what I mean.
Think of this simple circuit:
Vn 2 0 *something*
Rs 2 1 'Zsrc'
Ri 1 0 'Zin'
Where node 1 is the voltage on the input pin in question. The Vn source is any noise source. Ri is the input impedance of the buffer. Rs is the strength of the coupling between the noise source and node 1.
Without a pull-up the input impedance (Zin) can be quite high. For example I'm looking at a STM32 data sheet that says it can have an input leakage current into a GPIO as high as 350nA at 3.3V for a Zin=3.3V/350nA ~= 10MΩ.
So say Vin was a 2Vpp noise source coupled to this pin, and it didn't even have a trace, if Zsrc (the strength of the coupling) was anything less than (Vil=0.4*3.3)*10M/2=6.6MΩ then this noise source could exceed Vil(max) of this input. If I add a 10K pull down to the pin then it will be in parallel with Ri, lowering the load impedance of this net, and now for my same 2Vpp to trip Vil(max) the coupling needs to be less than 6.6KΩ, which is so strong that it's probably not going to happen by mistake.
Here is another point to consider. GPIOs which are off, or high Z, don't actually source 0A. My same STM32 can source as much as 10uA from the pad even in HiZ (Off transistors also leak, see the Idss line item in a FET spec) and that's enough current to drive our 10MΩ input all the way up to the power rail. If we add the 10K pull down then that same 10uA will only pump the input up to 100mV which is safely below Vil(max).
  • #45
I've used lots of MSP430's. I never realized they have internal pull-up / pull-down resistors. I never used them (I used SPI for communication).
When a FET is connected to a micro output pin, I always put a pull-up on the gate of a P Channel FET and a pull-down on the gate of an N Channel FET. This is to ensure the FET is "off" when power is applied.
The pull-up resistor impedance needs to be high enough for the micro output to properly sink the current. The pull-down resistor impedance needs to be high enough for the micro output to properly source the current.
  • #46
There will be different considerations for different situations.
For some products, such as smart watches, apart from the battery and LCD, the internal space left for the electronic circuit board is extremely limited, and some electronic sensors may be placed, including heartbeat sensor, accelerometer (pedometer), etc., the last remaining space may be just fit in a microcontroller (wafer/dice form) about 2mm by 2mm, so even the space occupied by a small 0402 resistor will be saved as much as possible. Moreover, when producing such small and dense circuit boards, the number of parts on the circuit board must be minimized to reduce the chance of failure and production costs.
  • #47
Good point! At my last project, inadvertently blowing up an oil refinery was not an option!
The 0201 resistor is a tiny size. They may make them smaller now.
A lightning strike can create a voltage pulse, that can misdirect the micro firmware, which could misdirect the micro output. When possible, I prefer a solder joint vs. relying on a micro output.
It seems that these precautions would be implemented for air planes, automobiles, etc.
Striving to have zero failures has always been my highest priority for all products! :-)
