How do we define and categorize technology?
  • Thread starter Thread starter shivaniits
    Technology
Defining and categorizing technology is complex, particularly with terms like "semiconductor technology," which can refer to various aspects, including the production, modification, and application of semiconductor materials. The term often serves marketing purposes, allowing companies to shape its meaning to fit their strategies. This ambiguity makes it challenging to create a precise definition, as evidenced by numerous articles and categories related to semiconductor technology found online. The discussion highlights the interplay between technology's technical aspects and its representation in media and marketing. Ultimately, the need for clear definitions arises from the broad and vague nature of such terms.
shivaniits
how do we define and categorize technology..??
there are presently different aspects in which the technologies are discussed
if i say semiconductor technology then should it mean..
1) technology that processes semiconductor materials to get high performance electronic devices..??
2) technology that uses semiconductor devices to get their information processed..??
Welcome to PF;
The "xyz technology" is most often a media/marketing useage and, therefore, means pretty much whatever the marketing folk want it to. It would refer to product that has something to do with the label.
Per your example, "semiconductor technology" would be anything that is involved with the the making, modification, usage, and knowledge of tools, machines, techniques, crafts, systems, and methods of organization, etc concerning semiconducting materials.
This is not restricted to information processing or even "high performance" electronics.
Note: There is a field in social sciences called "technology" though, also called STS.
The term "semiconductor technology" is practically impossible to define or to catagorize. It encompasses so many aspects that it defies quantification. For example, using Google Search and the terms "semiconductor technology" we find twenty-eight different Wiki pages are in this category:
http://en.wikipedia.org/wiki/Category:Semiconductor_technology
Here there are around one hundred separate articles on the subject of “semiconductor technology”
http://phys.org/tags/semiconductor+technology/
So why the need to define and catagorize the subject?
Bobbywhy
hello
amm..so i guess it all depends on perspective and the matter in which the label is associated with the company..and we could say it anything and it all depends on the marketing strategy...
correct me if i am wrong thanks..!
shivaniits, You are exactly correct: the term "semiconductor technology" is so broad and so vague that it can mean whatever the marketing strategy desires it to mean. You've got it!
Bobbywhy
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
