How Do You Calculate Error in Complex Physics Equations?
  • Thread starter Thread starter Exulus
    Calculation Error
The discussion focuses on calculating errors in complex physics equations, specifically using the equation E = m_{0}c^2 [\sqrt{1+(\frac{RqB}{m_{0}c\tan{\frac{\Theta}{2}}}) ^2} - 1]. Participants emphasize the importance of finding partial derivatives of each variable (R, B, and θ) and applying the chain rule to compute the overall error. A participant successfully navigated the process by treating non-variable components as constants, which clarified their understanding of partial differentiation. The method for calculating error involves the expression σ = √[(∂E/∂R)²(ΔR)² + (∂E/∂B)²(ΔB)² + (∂E/∂θ)²(Δθ)²].
  • Understanding of partial derivatives in calculus
  • Familiarity with the chain rule in differentiation
  • Basic knowledge of error propagation techniques
  • Experience with physics equations involving multiple variables
  • Study error propagation methods in physics
  • Learn about partial differentiation and its applications
  • Explore the chain rule in calculus in greater detail
  • Practice calculating errors in complex equations using real-world examples
Students and professionals in physics, engineers dealing with complex equations, and anyone interested in mastering error calculation techniques in scientific contexts.
Exulus
I really struggle with calculating errors :( I understand what i have to do, find the partial derivative of each variable and multiply it by the error, square it, add up all the others then square root the total. I just seem totally incapable of doing it :( The expression i have to find error on is:
Where R, B and theta all have errors associated with them! (to find the error on E)
I've been told its possible to break it down one bit at a time, so evalulating the RqB bit i get:
\sigma = \sqrt{ (B\Delta R)^2 + (R\Delta B)^2}
But no idea where to go next :( Any help much appreciated!
So are you having trouble with finding the partial derivatives in the uncertainty expression below??
\sigma=\sqrt{(\frac{\delta E}{\delta R})^2*(\Delta R)^2+(\frac{\delta E}{\delta B})^2*(\Delta B)^2+(\frac{\delta E}{\delta\theta})^2*(\Delta\theta)^2}
Hi,
Yeah i was having trouble with it. I think I've solved it now. I went an incredibly long way around it by calling everything else inside the bracket which wasnt the variable to be differentiated, a constant, such as C. That made me see what was going on a bit better and i think it worked! *fingers crossed* i can't change it now as the work has been handed in :) Thanks though!
yeah well that's all you do in partial differentiation anyway. You treat everything else as a constant except the variable you are differentiatin with respect to. Then in your case you had to apply the chain rule and bob's your uncle ;)
Good luck with it then and it sounds like you had the right idea so it should be ok.
  • · Replies 21 ·
  • · Replies 0 ·
