How Do You Calculate Point P3 in a Coordinate System with a 90-Degree Angle?
  • Thread starter Thread starter chuyler1
    Coordinate
The discussion revolves around calculating the coordinates of point P3 in a coordinate system where a 90-degree angle is formed between the lines connecting points P1, P2, and P3. The problem involves determining the relationship between these points given specific distance constraints.
  • Homework-related
  • One participant seeks to find the equation for point P3 based on known points P1 and P2, specifying that the distance from P2 to P3 should be 1/5 the distance from P1 to P2.
  • Another participant suggests showing previous attempts to clarify where assistance is needed.
  • A participant expresses uncertainty about how to start and mentions a potential simplification by adjusting P2's y-coordinate, although this may not yield accurate results in all cases.
  • One participant proposes using the property of slopes of perpendicular lines, indicating that the slopes of the lines connecting the points are negative reciprocals.
  • Clarification is sought regarding the definitions of the slopes m1 and m2 in the context of the problem.
  • A participant asserts that vector algebra can be used instead of calculus and questions whether the line P1-P2 could be vertical.
  • Another participant confirms that they are open to using trigonometric functions in their solution.
  • A later reply suggests that trigonometric functions may not be necessary and provides a method to calculate the coordinates of P3 using similar right triangles and a scale factor.
  • One participant confirms that the proposed method for calculating P3's coordinates works perfectly.
While there is some agreement on the approach to finding point P3, multiple methods and perspectives are presented, indicating that the discussion remains somewhat unresolved with respect to the best approach.
Participants express varying levels of familiarity with calculus and trigonometry, which may influence their proposed methods. The problem's complexity and the need for efficiency in calculations are also noted.
chuyler1
See the attached image first. Given that I know points P1 and P2, what would the equation be to get point P3, given that the angle is 90 degrees and the distance from P2 to P3 is 1/5 the distance from P1 to P2?
Thanks in advance!
Welcome to PF!
Hi chuyler1! Welcome to PF! :wink:
Show us what you've tried, and where you're stuck, and then we'll know how to help. :smile:
I haven't a clue where to begin. It's been 8 years since the last time I had to think about calculus. I found some equations on how to rotate a point by 90 degrees but the only examples are to rotate around (0,0).
This calculation has to be performed hundreds of times in a short amount of time so if the equation is too complex i may just fudge it by increasing point P2's y by L/5. It simplifies the problem but doesn't provide desirable results in all situations.
Could you use the fact that the slopes of perpendicular lines are negative reciprocals of each other? I.e.:
m1 = -1/m2
What is m1 and m2 in your equation?
They are the slopes of the two lines you drew.
m1 = slope of line P1-P2
m2 = slope of line P2-P3
No calculus is needed here... just vector algebra.
(Will P1-P2 ever be vertical?)
Are you willing to use trig-functions?
Yes, P1 and P2 are arbitrary, they could be any angle or even reversed. I have trig functions available to me so a solution involving them isn't a problem.
I've had some more time to think about this. We won't even need trig!
In the figure, note that we form two similar right triangles, with a scale factor of 1:5.
To get the x-coordinate of P3, subtract (y2-y1)/5 from x2.
To get the y-coordinate of P3, add (x2-x1)/5 to y2.
Awesome! Works perfectly!
11K
