How Do You Calculate the Closest Point of Approach for Two Moving Objects?
  • Thread starter Thread starter nikieme
    Approach
To calculate the closest point of approach for two moving objects, start by writing the equations of motion for each object based on their initial positions and velocities. Use the distance formula, which is the square root of the sum of the squares of the x and y coordinates. To find the minimum distance, differentiate the distance function with respect to time and set the derivative equal to zero to solve for time. The discussion highlights the importance of understanding motion equations and differentiation in solving the problem. This approach effectively determines when the two objects are closest to each other.
nikieme
Two objects 1 and 2 are moving towards each other, 1 along the x-axis and the 2 along the y axis. Initially, object 1 is at (- 28.9,0) (in m) moving at speed v 1 = 13.7 m/s, while 2 is at (0.-36.8) (in m) moving at speed v 2 = 7.5 m/s. How long does it take until the objects are at the minimum distance from each other? (give your answer in s)
I just don't know where to start from... like all i need is a hit or formula. I have no clue how to find the closest poing of approach.
*Btw i am new to the forum and this is the first time i am posting something. So, if i make any errors, kindly tell me.
Regards,
Nihant
write the equation of motion for each partile, i.e. x0+v1t, etc.
and use the distance equation sqrt(x^2 + y^2). then...
Thank you very much. I figured it out...and then you differentiate it and put it equal to 0 and solve for t...Thanks ;-)
You're very welcome, Nikieme
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
