How Do You Calculate the Conditional PDF for a Given Union of Events?
  • Context: Graduate
  • Thread starter Thread starter shespuzzling
    Conditional Pdf
The discussion centers around a homework problem involving the calculation of the conditional probability density function (PDF) for a given union of events. Participants explore the implications of the specified function and the conditions under which the conditional PDF is defined.
  • Homework-related
  • One participant expresses difficulty in calculating f(x|A) for the union of events defined by the conditions 1 ≤ x and x > 10, questioning the approach of using the complement of A.
  • Another participant provides a formula for the conditional PDF, suggesting f(x|A) = f(x)/∫Af(u)du for x in A, and f(x|A) = 0 otherwise.
  • A follow-up question seeks clarification on the limits of the integral and the meaning of f(u) in this context.
  • Another participant clarifies that the integral should be split into two parts, (0,1) and (10,∞), and explains that f is the given function, with u serving as a dummy variable for integration.
Participants do not appear to reach a consensus on the limits of the integral or the interpretation of the conditional PDF, indicating that multiple views and uncertainties remain in the discussion.
There are unresolved questions regarding the limits of integration and the implications of the union of events on the conditional PDF. The discussion reflects varying levels of understanding among participants.
shespuzzling
Hi,
This is a homework problem that I'm having a very hard time with. We are given that f(x)=e^(-x) for X greater/equal to zero. The question is to find f(x|A) where A is the union of the events (1 less/equal x, and x greater than 10). I can't figure out how to go about doing this...I thought of taking the complement of A and solving the conditional probability for x between 1 and 10, but then if I take 1 minus that, I don't think that f(x|A) will have an area less than 1, and it will also be negative at points. Any help is greatly appreciated.
Thank you.
f(x|A)=f(x)/∫Af(u)du, for xεA
f(x|A)=0, otherwise
Thanks for your help! But in this case, since A is less than 1 and greater than 10, what would the limits of the integral e? Also, what is f(u) in this case?
The integral just gets split up into two parts (0,1) and (10,inf).
Your second question makes me wonder about what level of math you are at. f is the function you are given. For the purpose of expressing the integral, u is just the dummy variable for integration - any other letter would do. I deliberately did not use x, since x is being used as the explicit variable for the expression.
