How Do You Calculate Var(X) in a Conditional Variance Problem?
The discussion focuses on calculating the variance of a random variable X given a conditional variance problem involving a discrete probability distribution. Participants share their calculations for expected values and conditional variances, with initial results leading to confusion about the correct values. A revised conditional probability mass function is proposed, which alters the expected values significantly. The conditional variance formula is referenced, and there is a request for clarification on the notation used in the probability distribution table. Overall, the conversation emphasizes the importance of accurately calculating conditional expectations and variances in probability theory.
grimster
the discrete prob distribution
X/Y - G - D
0 - 0,1 - 0,15
1 - 0,1 - 0,3
2 - 0,05 - 0,3
this is what i have so far:
E[X|Y=D]=0,2
E[X|Y=g]=0,9
E[X]=0,725
E[X^2|Y=D]=0,3
E[X^2|Y=G]=1,5
Var(X|Y=G)=0,69
Var(X|Y=D)=0,26
i.e. [X]=0,2*0,25 + 0,9*0,75=0,725
is the previous correct and how do i find Var(X)?
the conditional variance forumal is:
Var(X)=E[Var(X|Y)] + Var(E[X|Y])
:confused: I am not sure but it seems easier to calculate Var[X]= E[X^2]- (E[X])^2
you already have E[X]. you can try to calculate E[X^2] by conditioning on Y.
how do i do that?
secondly, i think I've might have made a mistake. i think i forgot to calculate the conditional probability mass function.
that would mean distribution, given Y=G) is i.e.
0 - 0,2
1 - 0,4
2 - 04
so then E[X|Y=G]=0,4+0,8=1,2
what is it? 1,2 or 0,9? i think the former 'result' is correct. so forget the other results, these are the corrected(?) ones
E[X|Y=G]=1,2
E[X|Y=D]=0,8
E[X^2|Y=G]=2
E[X^2|Y=D]=1,2
Var(X|Y=G)=0,56
Var(X|Y=D)=0,56
E[X]=1,1
i want to find Var(X)...
Your notation is confusing -- at least for me. What does the table
X/Y - G - D
0 - 0,1 - 0,15
1 - 0,1 - 0,3
2 - 0,05 - 0,3
stand for?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
