How do you derive a Range prediction equation?
To derive the range prediction equation, the initial velocity (v0) and range (R) are expressed in terms of time (t) and vertical displacement (Y). The equation for range is simplified to R = v0t under the assumption of zero acceleration. To find time, t is substituted with the expression \sqrt{\frac{2Y}{g}}, where g is the acceleration due to gravity. This substitution allows for the final range equation R = v0\sqrt{\frac{2Y}{g}}. Understanding the relationship between time and the event of the object's vertical displacement is crucial for this derivation.
genu
Derive the equations for v0 and R, and show how you made your prediction.
d = v0t +1/2at^2
The acceleration was zero, so I rewrote the equation:
R(range) = v0t
but then they substituted t with\sqrt{\frac{2Y}{g}} to get
R=V{0}\sqrt{\frac{2Y}{g}
How did they get that for t?
also note: that Y is the vertical displacement of the ball to the floor.
let me know if I need to attach the diagram that they provided
Hi genu,
d = v0t +1/2at^2
R(range) = v0t
Think about what the range R means in this problem. In other words, as the object moves, the x-displacement keeps getting larger and larger until some event occurs; what event is that? The time when that occurs is what tells you how large your range is, and so the time when that occurs has to be used in your range equation. Does that help?
