How do you evaluate this log equation?
  • Thread starter Thread starter haengbon
    Log
The discussion revolves around evaluating the logarithmic equation log39 + log41/64 + log51. Initial attempts to solve it involved incorrect interpretations of the logarithmic properties, leading to inaccurate results. Participants clarified that the correct approach involves calculating each log expression individually rather than combining them as equations. The final solution is derived as log39 + log41/64 + log51 = 2 - log464 + 0, simplifying to -1. Proper understanding of logarithmic identities is emphasized for accurate results.
haengbon
none
I tried answering it by...
(3x=9) + (4x=1/64) + (5x=1)
because of this, I got 5. Is that correct?
Hi haengbon! :smile:
Correct method :smile:, but wrong result :redface:
try (4x=1/64) again. :wink:
I tried it again and got -3 for 4x=1/64 :D is that correct now? ^^ thank you for the help by the way :)
Yup! :biggrin:
If you turn in work like this, your instructor will probably deduct points, since you are apparently trying to add three equations.
Each of the log expressions is simple enough to calculate, so your work should look something like this.
= 2 - log464 + 0
= 2 - 3 = -1
I used the fact that log(1/x) = - log(x) going from the first expression to the second.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
