How do you find how far a belt travels using diameter and rps
  • Thread starter Thread starter daniellen
    Belt Diameter
The discussion focuses on calculating the number of stitches a sewing machine makes and the distance a belt travels based on pulley diameters and rotations per second. The driver pulley has a diameter of 30 cm and operates at one revolution per second, leading to 600 stitches in 10 minutes. The belt's travel distance is determined by the circumference of the driver pulley multiplied by its RPM. If the driver is replaced by an electric motor with a 1.5 cm pulley, the necessary RPM to maintain the same sewing rate must be calculated using the ratio of the pulley diameters. Understanding the relationship between pulley circumferences and RPM is crucial for solving these problems.
daniellen
the foot operated sewing machine shown below has a driver pulley which is 30cm in diameter and is attached by a belt to a sewing pulley with a 5cm diameter. The sewing machine makes one stitch for each revolution of its sewing pulley.
a. The driver pulley is turned easily at one revolution per second.
-how many stitches does the machine make in 10 minutes?
-how far would the belt travel in 10 minutes?
b. if the foot pedal(driver) was replaced by an electric motor with a pulley of diamater 1.5cm, how fast would it need to turn to duplicate the same sewing rate?
I'm not sure what to put here, sorry.
for A, I answered: the driver makes 600 rotations per minute. 600*5= 3.000
and for the rest I have no idea how to complete because I was absent for the explanation.
Welcome to PF!
Hi daniellen! Welcome to PF! :smile:
Why *5 ? :confused:
The important point is that the belt goes at the same speed as the circumference of every pulley it's attached to (because it's not slipping) …
if it's attached to two pulleys, then their rotations (rpm) have to be such that their circumferences both move at the same speed (cm/s).
Try again. :smile:
I did 5 because it is the diameter but I was not really sure.
So then would you find the circumference of the driver and then multiply it by 600o(because it the driver makes 1 rotation per second and its asking about 10 minutes)
Why *5 ? :confused:
Try again. :smile:
Hi daniellen! :smile:
(just got up :zzz: …)
No. As I said …
So if the two circumferences have the same speed, then the ratio of their rpms must be … ? :smile:
the ratios would be six. so how do I implement that into finding how many stitches for 10 minutes and the belt?
No. As I said …
Stitches per minute = revolutions per minute …
and so … ? :smile:
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
