To find the magnetic field between finite wires, the Biot-Savart law is applied, integrating over the finite length of the wire rather than assuming it is infinite. The approximation of treating a wire as infinite typically holds until the distance from the wire is significantly less than its length, with a common cutoff suggested around 10%. This means that for distances greater than 10% of the wire's length, the infinite wire approximation may no longer be valid. The discussion emphasizes the importance of adjusting calculations based on the wire's finite length to achieve accurate results. Understanding these principles is crucial for precise electromagnetic field calculations.
#1
Frostfire
50
I know the results for infinite, but how about finite? And where is the cutoff with the aproximation of infinite? I've heard the value 10% tossed around is that right?
if u have used bio savart law to find the field of an infinite wire, u wud have integrated along the comple length (infinite) of the wire.
now just integrate along the finite ength of the wire
Do we even know? My understanding of dark energy is that particles come into existence, exert and outward force, then vanish. My problem with that is how, of course, then how does dark energy know to push everything in the same direction? The pressure exerted would be in all directions, even if the space was moving so why isn't stuff pushed all over the sky?
Thanks - rev
