How do you find the moment of inertia of a polygon?
Calculating the moment of inertia for a polygon can be challenging, especially for those with four or more sides. The discussion highlights the complexity of using polygons beyond triangles, particularly in 3D graphics where vertex alignment and shading become issues. The original poster seeks a method to find the moment of inertia without decomposing the polygon into triangles, specifically for convex polygons on a 2D plane. There is a mention of confusion regarding 3D concepts, which are not applicable to the 2D scenario being addressed. The conversation emphasizes the need for a straightforward approach to this calculation.
epaik91
I'm working on an engine right now, and I'm having trouble calculating the moment of inertia for a polygon. Is there any way to easily do this without decomposing the polygon into triangles?
edit: I've looked at the wikipedia page with examples on the subject (http://en.wikipedia.org/wiki/List_of_moments_of_inertia) and I'm having trouble understanding the last example, which seems to be what I need.
Mathematics news on Phys.org
That last example is, indeed, the moment of inertia formula for the polygon, and is the final result of having decomposed the polygon into triangles.
I derived it once for myself, I'm sorry that I'm not inm the mood to do it once again.
Any particular reason your polygons are not triangles in the first place? Polygons of 4 or more sides complicates everything.
4 or more sides means your polygon does not need to have all vertexes on the same plane, which complicates shading.
Building a BSP-tree gets more complicated the more sides your polygons have (you will end up splitting a whole lot).
and so on.
k
and so on.
k
I'm sorry if I wasn't clear, but I'm doing everything on a 2D plane. I'm not sure what you mean by stating that the vertexes won't be on the same plane, but I think you may be confusing 3D graphics with my problem (shading?). In addition, finding a way to solve this problem for convex polygons will achieve what I'm going for, which is why I'm avoiding BSP-trees or any other kind of decomposition of the polygon.
Yep, I was thinking 3D, sorry.
k
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
