How do you observe the position of an electron?
  • Thread starter Thread starter Helicobacter
    Electron Position
Helicobacter
How do you "observe" the position of an electron?
Do you use x-rays?
If so, what happens when you hit the orbital of a given atom with x-rays? Will it just accelerate the electron(s) out of the orbital? Also, how can you then infer the position the electron had initially occupied? Do you just have detectors set around the bombarded atom? Since you know everything about your fired x-ray (intensity, wavelength etc.), you can solve for the position at impact? EDIT: You probably can't, because which detector is hit by the electron depends on the velocity and position of the electron at impact (neither of which you know). EDIT2: But if you know the temperature of the atom, then do you not know at what velocity the kicked-out electron moves? EDIT3: You only know speed but not the actually direction of motion?
Then, when this experiment was repeated a lot of times, the probability density functions were established?
X-ray is just one of the solutions.
You may focus your X-ray on a very small area. So if you notice the electron kicked out - you are sure it got kicked from the focus point.
You may also build pretty small detector to catch electrons. Actually, such detector may be not much bigger than single molecule.
If you don't need such accuracy - watch TV (old-fashioned, CRT, not a flat one) As the electron hits the screen it flashes.
With current technology, at what resolution can we focus an xray beam (in units of a hydrogen atom diameter, say)?
But you don't know what the velocity of the electron was. You might know speed but not velocity. Is it not like Billiard balls? Does the velocity of the electron not matter (e.g., if the xray photon [the cue] hit the electron [8-ball], does the velocity of the 8-ball not matter at impact?
EDIT: Nevermind, you're right. You do not measure the final electron velocity or even which detector was hit - just the fact that is was kicked out, and the knowledge of which region within the orbital you beamed away.
EDIT2: What if you did measure terminal velocity (at detection) and terminal detector position? We know xray photon velocity, speed of electron at impact (from room temperature), velocity of electron at detection, detector position that's being hit by the electron - we can solve for velocity at collision. Also, from your inference we can determine position simultaneously. Therefore, I claim that the uncertainty principle is bogus. Where is my mistake?
you know it only with a degree of error, the smaller that error for velocity the greater the error for its exact position. Also you seem to be inferring that we can predict one thing from the result another, but we cant, not with certainty.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
