How do you obtain electrons and know their average velocity?
To obtain electrons for experimentation, a hot cathode electron emitter with a low work function can be used. Measuring the average velocity of the electrons can be achieved by utilizing a velocity selector in conjunction with magnetic and electric fields. The curvature or deflection of the electrons in these fields can provide data on their velocity. Additionally, tracking the accelerating voltage applied to the electrons allows for velocity calculations. This approach addresses the challenges in measuring charge and velocity in charge accelerators.
quantumfoam
How do you obtain electrons and know their average velocity??
Hello guys! I am currently trying to experiment with charge accelerators. I soon tripped inside a really big hole. I soon realized that I didn't know how to measure the amount of charge(in coulombs) a charged conductor has. So instead of using charged objects, I decided to use electrons. How would I go about obtaining electrons? Most importantly, how could I measure the average velocity of a beam of the electrons I obtained (if I am able to obtain them).
I am quite sure that there is a deeper problem in the whole setup...
To get the electron velocity, you can shoot them into a magnetic or electric field and measure the curvature/deflection. Alternatively, keep track of the accelerating voltage, and calculate the velocity based on that.
Hi guys! Yes, I thought about that last night. I decided to use a velocity selector and a hot cathode electron emitter with a low work function. The velocity selector will only allow the electrons with the desired velocity pass through the magnetic and electric fields. Provided that I apply enough energy to the hot cathode. Thanks!:smile:
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
