How does a resistor exactly reduce current flow in a circuit
8 replies · 3K views · last reply
tor2006
Greeting .
It is clear to me that the resistor represents a physical obstruction to the passing current I do not know how exactly it works and I will try to show what I was really interested in the diagram.
  • Hand-drawn circuit diagram of a closed loop with a battery at the top, plus and minus terminals marked, and a resistor on the bottom wire, with dashed lines showing electron flow and notes reading electrons are moving from negative to positive battery terminal.
tor2006 said:
Greeting .
Current is like a bicycle chain --- all parts move at the same time. Actual electron movement is MUCH slower than you probably imagine. Google "drift current"
You may also notice that the number of electrons entering and leaving the battery are equal. So one side cannot flow faster than the other.
tor2006 said:
Greeting .
Resistance is a property of the material; e.g. Metals have a lot of free electrons, which means in general they have less resistance. Higher the resistance, lesser the number of free electrons in the material. These electrons are what carries the current. (at speed of light)
No, electricity in conductors does not travel at c but at a slightly lower speed.
https://www.physicsforums.com/threads/electricity-doesnt-move-at-the-speed-of-light.5367/
No, they travel even slower ... Drift velocity is mm to cm / sec depending on conductor and magnitude of the current
https://en.wikipedia.org/wiki/Drift_velocity
The only thing that travels at near the speed of light is the pulse of the EM wave along the outside of the conductor
In a DC circuit, it is a single initial pulse when the circuit is switched on. In an AC circuit, it is a cycling pulse at the rate of the AC signal frequencyDave
A longitudinal wave of compression and rarefaction must also travel through the outer electrons in the conductor. Or not?
I specifically was not talking about electrons and drift velocity but electricity (that is, current)
basically the same thing ... current is the flow/movement of charge (s), those charges are the electrons
As I said, Only the EM wave travels at near light speed :smile:
