How can I increase the suction power of my cordless vacuum broom?
Increasing the suction power of a cordless vacuum broom is complex and not easily achievable through simple modifications. Attempting to increase the amperage or voltage beyond the manufacturer's specifications can lead to dangerous outcomes, including potential electrocution or motor failure. Many cordless vacuums utilize turbine-based designs, which have specific tolerances that are difficult to replicate without advanced machinery. The vacuum's performance may be limited by its design, especially if it was obtained for free, indicating lower quality. Ultimately, enhancing suction may not be feasible, and users should manage expectations regarding the vacuum's capabilities.
slee95
I was wondering about the how the suction works? I got this cordless vacuum broom for free and it has terrible suction. It runs on like 7 or 8 recharge c battery's and I was wondering if i increased the amperage or voltage would the motor run faster and have more suction?
I would not recommend increasing the volts/amps past the design specs, this will likely cause the motor to have a reduced lifetime, and may actually be dangerous to you (electrocution, motor catching fire / bursting).
In terms of how these work, many of them are turbine based - i.e. a radial turbine. But there are many many variations as you can imagine.
In general I would say that you won't be able to fix it yourself. The parts may be very tight tolerance that you can't replicate without CNC machines.
The clue is probably in the word "free". Designing and building an efficent compressor isn't easy. Probably the best you can hope for is that it produces a fairly high volume of air flow, not a high suction pressure with the inlet blocked.
So increased air flow to the motor should increase the suction of the vacuum?
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
