How Does d-d Transition Occur with No Free Higher Energy d-Orbitals Available?
The discussion revolves around the mechanism of d-d transitions in transition metal complexes, particularly in the context of the availability of higher energy d-orbitals when these orbitals are involved in coordinate bonding with ligands such as CN-. Participants explore the relationship between valence bond theory and crystal field theory in explaining these phenomena.
  • Some participants question how d-d transitions can occur when higher energy d-orbitals are occupied by coordinate bonds with ligands like CN-.
  • Others argue that the d-orbitals form covalent bonds with sp hybrid orbitals on carbon, suggesting a specific bonding configuration.
  • A participant asserts that d-d transitions occur within a transition metal or ion and do not happen between two atoms, particularly not with carbon.
  • There is a discussion about the nature of dative bonds and how exciting a d electron could lead to different bonding scenarios.
  • One participant expresses confusion regarding the relationship between valence bond theory and crystal field theory, noting that they are used to explain different properties of complex compounds.
  • Another participant emphasizes that while crystal field theory is typically used for absorption spectra, explanations using valence bond theory are also valid and should not be disregarded.
  • A participant reflects on their misunderstanding of the theories and clarifies their thought process regarding the formation of coordination bonds and subsequent d-d transitions.
Participants express differing views on the relationship between valence bond theory and crystal field theory, with some asserting they are distinct while others suggest they may be interrelated. The discussion remains unresolved regarding the specifics of d-d transitions in the context of occupied d-orbitals.
Participants highlight limitations in their understanding based on the complexity of the theories involved and the potential for confusion in educational materials. There are unresolved aspects regarding the definitions and implications of the bonding theories discussed.
leojun
how does d-d transition take place when there are no free higher energy level d-orbital's left(as the only two higher energy d orbitals form coordinate bond with CN-?
Chemistry news on Phys.org
The d-orbitals form a covalent 2-electron bond with the sp hybrid orbitals on C. So in each bond there are 2 orbitals involved which can take up up to 4 electrons.
nope,they form a special covalent bond called coordinate covalent bond with cn- and d-d transition happens within a transition metal or ion only.d-d transition doesn't happen between two atoms especially not with c.
The dative bond looks like ## \mathrm{Fe \quad C \uparrow\downarrow \longleftrightarrow Fe \uparrow \quad C\downarrow \longleftrightarrow Fe \downarrow \quad C \uparrow }##.
If you excite a d electron into that bond, you get a weaker 3 electron bond ## \mathrm{Fe\uparrow \quad C \uparrow\downarrow \longleftrightarrow Fe \uparrow \downarrow \quad C\uparrow } ##.
but there can only be two electrons in an hybridized orbital
Yes, if you look, neither the d orbital un Fe nor the sp hybrid orbital on C contains more than 2 electrons in any of the resonance structures.
sorry for the disturbance brother,Dr Du . I wasn't satisfied,so i went to a near by book store and searched every single book on this topic.guess what i found...I FOUND THAT THERE WAS NO RELATION BETWEEN VALENCE BOND THEORY AND CRYSTAL FIELD THEORY(they are two different theories used to explain different properties of complex compound's.for example-VALENCE BOND THEORY is used to explain the orientation of the ligands around the central metal atom or ion where as the CRYSTAL FIELD THEORY is used to explain the coloration of complex compound ).
It is true that crystal field theory is usually used to explain absorption spectra of complexes. However, that doesn't mean that an explanation in terms of VB theory isn't possible and as a trained theoretical chemist I would be rather worried if there were some qualitative properties of a molecule which I could explain using one theory but not, without good reason, some other.
The diagram you were showing in your first post alludes clearly to valence bond theory, as it introduces d2sp3 hybrids and first shows up in Pauling's book "The nature of the chemical bond", who uses mostly VB theory. Hence I tried to give you an explanation in terms of VB theory. If your question was in reality about crystal field theory, then I wonder why you didn't say so in the first post.
To be true,i didn't know that there was a VB theory way to explain it.i thought VB theory and CF theory were interrelated.
what i thought-
step 1 - coordination bond forms between ligand and central metal atom or ion forming complex ion
step 2 - after the formation of complex ion,CF theory comes into play and gives color to the complex ion(through d-d transition)
i wanted to know how d-d transition took place when there were no free higher energy level d-orbital's left(as the only two higher energy d orbitals formed coordinate bond with CN-. this confusion was due to my comprehensive textbook(gives info about all aspects but in a confusing way). thank you for your time:)
  • · Replies 29 ·
  • · Replies 56 ·
