How Does Doubling the Mass Affect the Frequency of a Spring System?
  • Thread starter Thread starter SignaturePF
    Springs
The discussion revolves around the effects of mass on the frequency of a spring system, particularly focusing on how doubling the mass influences the oscillatory behavior of the system. The context includes analyzing the relationship between mass, spring constant, and oscillation frequency.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants explore the relationship between mass and spring tension, questioning how forces interact in a system with two masses. There are attempts to clarify the displacement of each mass during oscillation and how it relates to the spring's stretch.
The discussion is active, with participants engaging in conceptual exploration of the oscillatory motion of two masses connected by a spring. Some guidance has been offered regarding the movement of the masses in relation to their equilibrium positions, but no consensus has been reached on the implications for frequency or spring behavior.
Participants are grappling with the definitions of equilibrium and oscillation, as well as the interpretation of forces in the system. There is an ongoing examination of how to visualize the motion of the blocks and the spring's response to their movements.
SignaturePF
https://aapt.org/physicsteam/2010/upload/2009_F-maSolutions.pdf
#16
ω = √(k/m)
So in this problem, I thought that given two identical masses on each side (that exert let's say Force F each), the net tension is not 2F, but F. This the force that is resisted is F = - kx, not twice that. I thought that there was nothing special about k, but apparently I'm wrong. Also, I thought given two objects, the mass is 2m; yielding the following answer:
√(k/2m) - The wrong answer.
The correct one is :
√(2k/m)
Imagine the blocks sitting at rest with the spring unstretched so each block is at its equilibrium position. Think about how you would start the system oscillating so that each mass oscillates about its equilibrium position with the midpoint of the spring always staying at rest.
If at some moment of the oscillation the block on the right is a distance x to the right of its equilibrium position, where is the other block in relation to its equilibrium position? How much is the spring stretched in terms of x? How would you write the force that the spring exerts on the right-hand block in terms of x?
Well if A is the amplitude, I would think that as one block is X to the right, the other would be A-X to the left. The spring is stretched by A-X + X = A? The force that the spring exerts on the right-hand block I'm not sure how to write.
If one block has moved 0.1 m from its equilbrium position, how far has the other block moved from its equilibrium position? How much has the spring stretched?
The other block compresses .1m?
Yes, for the .1 m. Not sure about the interpretation of "compresses". Consider the figure below which shows the equilibrium position of each mass. If at some instant block B happens to be displaced a distance x to the right of its equilibrium position as shown, then where is block A at this instant in relation to its equilibrium position?
To the right of its EP.
No. If both blocks move to the right by the same distance, then the whole system simply displaces to the right with no change in the amount of stretch of the spring. That would not correspond to oscillatory motion of the system.
Whoops. Where can I study oscillatory motion with two masses - my text is no help.
Must it move x to the left?
Yes, it must move to the left.
Imagine starting the system oscillating by simultaneously pulling block A to the left a certain distance and block B to the right the same distance and letting them go at the same instant. Can you visualize what the system will do after that?
They will oscillate between getting relatively close to relatively far away
So, if block B has displaced a distance x to the right of its equilibrium position, block A will have displaced a distance x to the left of its equilibrium position. How much has the spring stretched from its natural length? (Express in terms of x.)
  • · Replies 17 ·
  • · Replies 18 ·
  • · Replies 31 ·
