How Does Faraday's Law Explain EMF Induction Outside a Solenoid?
103 replies · 20K views · last reply
aaaa202
Today we did an experiment with a solenoid through which we varied the current. Around this solenoid, was a different circuit (not coupled to the coil-circuit) where we measured the potential across a resistor. By varying the current my teacher showed how the potential over the resistor would vary.
Now faradays law essentially says that a time varying magnetic field induces a rotating electric field.
∇xE = -dB/dt
So I thought that the above experiment could be explained by the fact that the changing magnetic field induces an electric field which accounted for the electromotive force induced in the other circuit and thus any drop or increase in potential.
BUT! As my friend correctly stated, the only place where the B-field is non zero is inside the solenoid itself. The circuit of the resistor was not a part of the inside of the solenoid. So -dB/dt would have to be zero for all points in space except inside the it. And that means no electric field can possibly have been induced from the varying magnetic field in the solenoid into the circuit of the resistor.
So how is the above experiment explained?
∇xE = -dB/dt
Curl of E is only non-zero where a B field exists also, but this does not mean the circulation of E requires magnetic field lines coincident with E field. The integral version of Faraday's law simply states the line integral of E around a closed path equals the negative of the time-changing rate of magnetic flux threading through such a closed path. Strictly speaking, for such transformer action situation, E is given at any point by minus the time-changing rate of A, the vector potential, and there can certainly be a non-zero A in the absence of a B at that point. Just check out the Wiki page http://en.wikipedia.org/wiki/Faraday's_law_of_induction
Come again please..
If the B-field is zero outside the solenoid, so is also the change of it in time and therefore the curl of E at those points. Where am I going wrong with this statement?
The B-field isn't really zero, just very small. But I don't think that's the point.
Take the integral form of Faradays law: i.e. that the surface integral of dB/dt is equal to the line integral of E around a closed contour which bounds that surface. Imagine then drawing a closed loop around your solenoid and any open surface which has this closed loop as its boundary. Is there is a non-zero flux of dB/dt going through that surface? If so, then the line integral of E around that loop (which is not inside of the solenoid) has a non-zero E.
Why should the B-field be zero outside the solenoid? You don't have an infinitely-long solenoid, do you?
Well suppose we had. Would the experiment still yield the same? Either way we can savely assume that the field is very small outside and thus the change in that should not induce a very strong electric field.
aaaa202 said:
Come again please..
As per my #2, and #4, one has to distinguish between the differential property curl E as 'vorticity' of the field, which is an intensive property of E, and induced emf around a closed path, which is an extensive or 'global' property. Stick with the definition E = -∇phi -∂A/∂t and you won't go wrong.
This is only correct if you have an infinitely long solenoid.
Yes, see my post.
If you had an infinitely long solenoid, then no, the experiment would not have the same result. Regardless of length, why do you assume the exterior B-field to be "very small?" If this were the case, then transformers wouldn't exist.
I can see that the flux of b through a closed area bounding the solenoid is non-zero. Thus you conclude that the integral of E around a closed path bounding the solenoid is non-zero - is that correctly understand.
Problem is just that doesn't get us very far. For where did this E-field generating a non-zero value for a closed line integral come from? It must come from the changing magnetic field. But that says ∇xE = -dB/dt
problem is just that the above would give zero. It seems the integral and differential form conflict with each other.
The magnetic field lines outside the solenoid tend to much "further" spaced apart than inside the solenoid (i.e. the flux outside << flux inside)
I think you're getting a little bit confused. Think of Ampere's law. A magnetic field curls around some current. Imagine that current is due to a wire. Now imagine you are calculating the magnetic field far away from the wire. You still have a magnetic field even though there is no current close to where you are.
Another thing, take the line integral of E around a closed loop. But now have the loop off to the side of the solenoid. That line integral will equal to zero because the - and + contributions will cancel each other out. BUT even though the line integral of E is zero, that doesn't mean that E itself is zero at any point. Does that help a little bit to give you a conceptual understanding?
I think I found an article describing this exact problem. I would have to say it agrees with me, and that the reasons for the voltmeters to change measurements is far more subtle than the reasons above. Do you disagree? If so, I have misunderstood you.
Emguy: I think you misunderstand the problem. The field is ZERO everywhere except inside the solenoid. Google the field of a solenoid.
Yes. It is the manifestation of the integral form of Faraday's law - and that's the only one applicable to your case.
No they don't. As stated in #7, the curl E version yields an intensive field property, valid 'at a point'. You want the net voltage around a circuit, then use the integral form, which only requires that some value of flux threads the circuit of interest. Note that this works perfectly in the case of a toroidal transformer configuration, which if properly constructed, has precisely zero magnetic field intersecting the secondary windings. Again, if in doubt always refer back to the definition for E, which here amounts to -∂A/∂t, as electrostatic fields are irrelevant to emf.
I find it hard to distinguish between the cases. If you look at the line integral around the solenoid as a sum of E*dr and have at each point that E is zero then WHY would the integral not yield a big, whopping zero?
Please take a look at the first page of the article attached above so you are sure what my problem is.
You are probably right, but I don't see it with your explanation.
Just because curl(E) is zero doesn't mean that E is zero.
Think of curl(E) as a line integral over an infinitesimally small loop. Thus curl(E) will be zero outside the solenoid because the sum of each of those infinitesimally small sides will equal to zero. Similarly you could deduce that curl(E) would be equal to zero over that infinitesimally small loop because if you use faradays integral form / Stroke's theorem you will see that there is no dB/dt going through the loop.
Not true.
Not true.
http://en.wikipedia.org/wiki/Soleno...ctor_potential_for_finite_continuous_solenoid
You are starting from some false assumptions, and reaching erroneous conclusions. The field outside the solenoid in your lab experiment was NOT zero.
A skim of that article makes it clear the circuit(s) considered introduce complexities not presented in your #1, which all assumed involved a simple case of measurement across the terminals of a secondary winding. The circuits in that article require application of Kirchoff's circuital laws in general, and obscure the simplicity of just dealing with application of Faraday's law in integral form. You agree transformers work, right?
DaleSpam said:
Not true.
Not true.
Something that might help you understand why this is true is magnetic field lines have to close on themselves (i.e. no such thing as a magnetic monopole). The only way for them to close on themselves is for them to loop back around outside the solenoid. Irregardless of this, if the magnetic field was zero outside (a theoretical situation) then you would still have an electric field outside the solenoid.
The article introduces exactly the problem that I introduced. Probably, I did not explain it very well though. Let me quote:
"Because curl E = 0 outside everywhere outside the solenoid it is tempting to conclude that the line integral between any two points is path independent. This is not true because of the topology of this region. Even though curl E vanishes in this region it is not simply connected and thus ∫Edr is not necessarily path independent."
Can anyone explain what the author tries to say with the region being not simply connected?
Dale: For a long solenoid the field is practically zero outside, and thus changes in dB are sufficiently small to be ignored. Have a look at the article posted if you have trouble understanding my problem.
I know that in reality the field outside will be there. It will just be extremely weak and not at all able to produce significant changes in the E-field. Indeed, as stated in the article, the solution to the problem is NOT that the B-field outside is always there but just extremely weak.
I don't see what you mean by "curl of E = 0 doesn't mean E is zero". That is not the point - of course there is an electric field outside the solenoid - but it is conservative. The whole idea of this experiment is to show that the electric field outside the solenoid is not conservative - something which DOES require curl E = 0!
Maybe you should take the time to write out EXACTLY what it is you do not understand. I am not sure what it is that is confusing you. I believe that quote is essentially saying that the E field outside the solenoid is not a conservative field (as one might assume if you say that the curl(E)=0).
what? curl(E)=0 => conservative field. But our field is not conservative. Please read the 2 first pages of the article, it shouldn't take that long and it describes exactly the problem I am trying to address.
Path independence (meaning 'simply connected' as applied here) is the property of a conservative potential - i.e. electrostatic case where E = -∇phi applies. Thus if there is a charged capacitor, no matter which path taken, moving from any point on one plate to any point on the other plate, the potential difference will be identical regardless of the path taken. In the case of transformer action where E = -dA/dt, net emf owes to a non-conservative field and is entirely dependent on the path taken. So, a secondary with N turns of wire circling the core where flux is concentrated, will read N times as much voltage across the terminals as for a single turn circuit. Those 'split circuits' in the article manifest the difference between these two basic situations.
Practically 0 is not 0. Furthermore, something which is "practically 0" can still have an arbitrarily high rate of change. Your assertions are simply false, the field is non-zero, and the rate of change of the field is also non-zero.
I know nothing about transformers.
You have probably said the solution to my problem in the previous posts but I just don't understand it. So let us for a last time try to come to a conclusion - else I will have to ask my teacher instead but last time he said he couldn't explain it properly and referred me to read the article above.
Let us simplify our problem, this way I should make it perfectly clear what bothers me. We imagine the problem to 2D. We have two regions in space, 1 and 2. Inside 1 the B-field is nonzero and outside B=0. Outside and inside there is an electric field E which can be anything but has to be generated by electrostatic charges, i.e. curl(E)=0.
We now imagine changing the B-field inside region 1. Clearly the changing B-field induces an electric field inside this region as described by:
∇xE = -dB/dt
Outside however nothing changes. B=0 and it remains so. Therefore -dB/dt=0 and ∇xE=0.
BUT! As the experiment and article stipulates. This is wrong. For some reason ∇xE is not equal to zero even in region 2!
I hope that I have now finally made it crystal clear what my problem is.
And the solution is NOT(!) that B-field is only almost non-zero for all experiments performed in real life.
I completely understand your way of thinking. I actually thought the same initially but according to the article it does not seem to be the true reason, rather it is a problem of the topology of the region outside the solenoid - but I don't understand it too well.
Would you mind reading the 3 first pages of it, and explain to me what the conclusions are? If your idea is actually right after all, then I am happy because I understand what you think. I am just not unsure, on the basis of the article, that you are right.
