How does grounding cause dissipation of charge
Grounding an object with a net charge allows it to neutralize by connecting it to a charge reservoir, which either absorbs excess electrons or provides missing ones. This process effectively spreads out the charge, leading to a negligible net charge on the object. The ground acts as a stabilizing force, ensuring that charged objects reach electrical neutrality. This concept parallels other scientific principles, such as reservoirs in thermodynamics. Understanding grounding as a charge reservoir is essential in various scientific contexts.
Fibo112
When an object with a net charge is connected to the ground by some conducting material the net charge disappears. The only answer I was able to find was that the net charge gets spread out, which will clearly cause it to become negligible. What causes this to happen?
The "ground" can be considered as a reservoir of charges. If a material has too many electrons, the reservoir will take as many as it takes until the object becomes neutral. If it has a lack of electrons, the reservoir will give as many as it needs until it becomes neutral.
That is all you need to care about regarding this "ground". This won't be the first time you encounter a "reservoir" like this. You'll see one when you do thermodynamics and the Carnot cycle.
Zz.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
