How does lightning work? (one strike or multiple strikes?)
This discussion clarifies the mechanics of lightning strikes, emphasizing that voltage does not flow; rather, it is the current that flows during a discharge. When a thundercloud, potentially holding up to 1 billion volts, discharges, it can release energy in multiple strikes rather than a single bolt. The electric field generated between the cloud and the ground must overcome air resistance for a discharge to occur. Observations indicate that multiple discharges can happen along the same path, with instances of up to eight pulses recorded.
  • Understanding of electric fields and potential difference
  • Knowledge of current flow in electrical discharges
  • Familiarity with lightning leaders and streamers
  • Basic principles of atmospheric electricity
  • Research the mechanics of lightning leaders and streamers
  • Explore the differences between voltage and current in electrical phenomena
  • Study the atmospheric conditions that lead to lightning formation
  • Investigate the effects of multiple lightning strikes on structures and landscapes
Students of meteorology, electrical engineers, and anyone interested in the physics of lightning and atmospheric electricity.
ARC123
I am mainly asking if it's possible for a thunder cloud to release its sorted energy in burst rather than in one strike. Like if a thundercloud had 1 billion volts would it be possible to great small sparks that allow it to shoot of 5 lighting strikes of different voltages rather than one strike of 1 billion volts.
Science news on Phys.org
Sometimes when there is sever lightening, you can see multiple strikes released from a thunder cloud consecutively. Is that what you mean? Usually, you will see one large strike with branches. Then secondary strikes that follow the initial bolt of lightning follows shortly. All of this is an attempt to neutralize charge.
Oh, and this is rather thrilling:
Something like that. What I am really asking is say you had a thundercloud. It had 1 billion volts stored in it. Now when it discharges, a single or what you said 2 bolts of lighting. What I want to know is,(with the help of man or just by itself) would it be possible for the thunder cloud to release all of its stored energy in burst of electricity. Sort of like a batter expect it gives off energy in burst of multiple strike.
hi there
you have a bit of a misunderstanding of voltage. Voltage DOESNT flow in the lightning strike or in any other situation, Current does.
As the voltage( potential difference between the cloud and the ground, or between 2 points in a cloud, build up, an electric field is
generated between say, the cloud and the ground. This electric field needs to build up to a point where it overcomes the air gap resistance
between the cloud and the ground. Once that potential difference is reached, a discharge occurs, and current flows.
There are some finer details of the initiating of the discharge, you can google lightning leaders and streamers
During the discharge, huge amounts of current flows, often 10's of 100's of Amps
Some strikes are primarily a single discharge down the channel path. Others are multiple discharges down the same path.
I have often counted and or videoed up to 7 or 8 pulses down the same path
Once the discharge has occurred, the voltage ( potential difference = electric field again starts to build up and the cycle repeatsDave
  • · Replies 44 ·
  • · Replies 58 ·
