How Does Mass and Inertia Affect Acceleration on an Inclined Plane?
The discussion revolves around a physics problem involving a block sliding down an inclined plane, taking into account mass, inertia, and friction. The scenario includes a flywheel and requires the application of torque and rotational dynamics concepts.
  • The original poster attempts to derive an equation relating tension, acceleration, and the moment of inertia of the flywheel. They express uncertainty about the role of the flywheel's mass and moment of inertia in their calculations.
Participants are engaged in clarifying the calculations and discussing the results obtained. There is a recognition of potential errors in rounding and the importance of precision in the final answers. Some participants share their computed values for acceleration and tension, indicating a collaborative effort to verify results.
Participants are working under the constraints of homework guidelines, which may limit the extent of assistance provided. There is an emphasis on understanding the relationship between the components involved in the problem rather than simply arriving at a solution.
ASUengineer16
A block with mass m = 5.00 kg slides down a surface inclined 36.9 degrees to the horizontal (the figure View Figure ). The coefficient of kinetic friction is 0.23. A string attached to the block is wrapped around a flywheel on a fixed axis at O. The flywheel has mass 28.0 kg and moment of inertia 0.500 kg*m^2 with respect to the axis of rotation. The string pulls without slipping at a perpendicular distance of 0.200 m from that axis.
I tied solving for the sum of torques, which is T*r=I*([tex]\alpha[/tex]) where T is the tension and r is the radius of the pulley, .200 m. I think solved for T for the box. Once solving for T I got, T=mg(sin(theta)-cos(theta)*[tex]\mu[/tex]k)-m*a. Then using the rule, [tex]\alpha[/tex]=a/r, I then substituted a/r for all the [tex]\alpha[/tex]'s and then plugged my T for the torque equation into the T from the force equation.
In the end I came up with the equation:
mg(sin(theta)-cos(theta)*[tex]\mu[/tex]k)-m*a = (I*a)/r^2
This yeilded me the wrong answer and I have no idea where I am wrong. I have a feeling it has to do with the mass of the pulley since it was given, but I am not sure how to relate it to the problem since they give you the moment of inertia for the pulley ?
Any help would be great thanks !
Hi ASUengineer16,
What wrong answer did you get?
After solving for a in the final equation I got 1.1 m/s^2
actually seems like I made a rounding error, the correct answer was 1.165 m/s^2 but it wouldn't take 1.1 when I entered it,
and for part b, 14.6 N came out to be correct with 1.2 m/s^2 as the acceleration.
I was about to write back that I kept getting 1.16619 for the acceleration.
Glad it worked out.
  • · Replies 27 ·
10K
9K
  • · Replies 18 ·
