How Does Setting Rx to 60k Affect the Output Voltage in an Ideal Op Amp Circuit?
The discussion revolves around determining the output voltage of an ideal op-amp circuit when a variable resistor Rx is set to 60k ohms. Participants explore the implications of this setting on the circuit's behavior, focusing on nodal analysis, current relationships, and voltage dividers.
  • Homework-related
  • One participant questions whether Rx is in series or parallel with R2, suggesting it may be parallel due to the current having multiple paths.
  • Another participant clarifies that while V+ and V- are equal, they are not necessarily zero, indicating a need for further analysis.
  • There is a discussion about the relationship between currents iR2 and iRx, with some suggesting they are equal and others debating the implications of this on the circuit configuration.
  • One participant expresses that the complexity of the problem exceeds their current study requirements but believes that tackling such problems will enhance their understanding.
  • Multiple participants provide differing answers for the output voltage, with one stating 4.8V and another stating 12.6V, highlighting uncertainty in the calculations.
  • Another participant mentions using the current divider rule to arrive at their answer, indicating different approaches to the problem.
  • One participant concludes with a detailed calculation that approximates the output voltage to 4.8V, suggesting a method involving KCL at every node.
Participants express differing views on the configuration of the resistors and the resulting output voltage, with no consensus reached on the correct approach or final answer.
Participants note confusion regarding nodal analysis and the relationships between currents and voltages in the circuit, indicating potential gaps in understanding that may affect their conclusions.
This discussion may be useful for students studying op-amp circuits, particularly those interested in nodal analysis and current relationships in electrical engineering contexts.
shifty101uk
1. http://img248.imageshack.us/img248/8971/opampanalysisxe2.png
Assume that the op amp in the circuit shown is ideal.
a.) Find the output voltage when the variable resistor Rx is set to 60k
Assuming Ideal Op amp. All currents leaving nodes are negative.
V+ = V- = 0 and In = Ip = 0
-ip - iRx + iR2, so iR2 = ip + iRx, as ip = 0
iR2 = iRx
-in + iR3 -iR1, iR3 = in + iR1, as in = o
iR3 = iR1
iR2 = Vs/R2 , iRx = Vs/Rx (is Rx in parallel or series?).
iR3 = Vo/R3, iR1 = VR1/R1
so far is this correct? Is Rx in series or in parallel with R2? I am pretty sure its in parallel(as the current has 2 different paths to go.) but I am not sure. The V+ = V- = 0 and i+ = i- = 0 assumptions are confusing me at the moment.
Some of the other unknowns can be reduced by voltage dividers. My main problem is determining the Nodal Voltage formulas on these circuits. I had a go anyway.
(Vn-Vo)/R1 + Vo/R3 + (Vs-Vp)/R2 + Vp/Rx = 0
im guessing this is probably wrong. If anyone could give me some pointers in the right direction I would be very grateful. I am going to review Nodal analysis at some point tomorrow and have another go at the problem.
hints:
V+ =V- but not zero, to be determined
iR2 = iRx as you have shown so iR2 not equal Vs/R2
iR3 not equal to Vo/R3
i+ = i- =0 is ok
Ok, I was really tired when I made this post but I think I get your hints. Is Vo divided over R3 and R1 as they are both in series as a voltage divider? I see what you mean about iR2 = iRx but not equal to Vs/R2, would it be equal to Vs/Rx? (actually, ignore that...its a current divider between Rx and R2).
This is more complicated than I need to learn for my exam, but I just see it as...If I know how to complete more complex problems my understanding can only get better
first question: yes
second question: don't think so... if iR2=iRx then R2 and Rx are in series... do a KVL loop if still unsure but it is simple to work out iR2 or iRx
in that case, you better clear up those ideas, for otherwise you may confuse yourself... this is a standard op-amp problem...
ok so Rx and R2 is another voltage divider, actually I have just spotted where most of my confusion lies, so this has just become so much clearer, thanks. I do still need to review nodal analysis.
hmm tried doing the q...do u have the answer to this q...? I got 4.8V but i didnt use any current thingy, just all on current divider rule
i have 12.6
hey, the answer is 4.8V i got the answer in the end and my understanding of op-amps is now pretty solid. Thanks Physforums
i've rounded off
[(Rx+R2)/Rx]*.4 = V+ or [(60000+15000)/60000]*.4 = .32
[R3/(R3+R1)]*V+ = .29 or [63000/(63000+4500)]*.32 = .29
[(R3/R1)*V+]+.29 = 4.77 or [(63000/4500)*.32]+.29 = Voclose enough to the 4.799 on the sim, don't know what i was thinking :-p
Hey,the answer is 4.8V. Remember in case of OP AMPs u need to apply KCL at every node.
  • · Replies 18 ·
  • · Replies 19 ·
