How does the current divide in parallel inductors?
The discussion centers on the application of the current divider rule versus the use of the formula V_O = L*(di/dt) in solving a transient problem involving parallel inductors. The initial attempt to apply the current divider rule resulted in an incorrect answer because it assumes a steady-state solution and does not account for initial conditions. The correct solution incorporates transient analysis, revealing that at t=0, each inductor carries 2A, which contradicts the expected 3:5 ratio. The voltage divider rule is valid for resistors but not for inductors, where the relationship involves the rate of change of current. Ultimately, understanding the differences in these approaches is crucial for accurately solving transient problems in circuits.
jangchen
In the circuit of Fig. 63.82 io(0)=2mA. Determine io(t) and Vo(t) for t>0
$$V_O = L*\frac{di}{dt}$$
I apologize using English fluently because I am not an Enlgish speaker.
When I tried to solve this problem, I used current divider rule.
So, $$i_o(t) = \frac{3}{3+5}*4e^{-2t} = 1.5*e^{-2t} A$$
However, This was wrong.
The answer is $$ 1.5*e^{-2t} + 0.5 A$$
If I use $$V_O = L*\frac{di}{dt}$$ , I can get right answer.
I wonder why there is a difference
between using current divider rule and using $$V_O = L*\frac{di}{dt}$$.
Likes Delta2
The current divider rule assumes a steady state solution. This is a transient problem. The current divider rule doesn't properly account for the initial conditions. At t=0 each inductor has 2A, which isn't consistent with the 3:5 ratio.
The voltage divider rule is valid for resistors, when the voltage is proportional to the current, U=RI. In case of inductors, this is not true, U=LdI/dt instead.
Likes jangchen and Delta2
Thank you for your advise! I got what is a steady state right away.
Oh, I thought current divider was also applied to the inductor. Thank you for your help!
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 19 ·
