How does the duration of acceleration affect the Twin Paradox?
  • Context: Graduate
  • Thread starter Thread starter Karl Coryat
    Paradox Twin paradox
The discussion centers on the implications of acceleration duration in the context of the Twin Paradox, particularly when one twin experiences a gravitational slingshot maneuver. Participants explore the effects of acceleration and gravitational time dilation on the aging of the twins, examining both general and special relativity perspectives.
  • One participant describes a scenario where Twin A uses a gravitational slingshot instead of direct acceleration, questioning how onboard clocks perceive acceleration and gravitational effects during the turnaround.
  • Another participant suggests that the situation is akin to other free-fall scenarios, emphasizing the complexities introduced by general relativity compared to special relativity.
  • A participant proposes that the time dilation formula must be integrated due to Twin A's non-inertial frame during the trip.
  • It is noted that general relativity allows for different proper times along geodesics, which cannot be accurately described using special relativity alone.
  • One participant clarifies that even in free-fall, the curvature of spacetime affects the proper time experienced by the onboard clocks, contributing to the aging difference between the twins.
  • A variant of the Twin Paradox is introduced, involving two observers moving in opposite directions without acceleration, which some participants argue does not represent a true differential aging scenario.
  • Another participant expresses skepticism about the validity of the variant, arguing that it lacks a physical basis for differential aging without proper acceleration.
Participants express differing views on the validity of the gravitational slingshot scenario and the proposed variant of the Twin Paradox. There is no consensus on whether the variant accurately represents differential aging, with some asserting it is merely a mathematical exercise rather than a physical phenomenon.
The discussion highlights the complexities of integrating general relativity and special relativity concepts, particularly regarding the treatment of inertial frames and proper time in scenarios involving acceleration and gravitational effects.
  • #31
ghwellsjr said:
Then we both agree that the 'capsule summary" phrase saying that the time differential occurs during the acceleration is really bad, correct?
Personally, saying "accumulate proper time along the paths" is no different than saying "the time on the clocks as they travel" and doesn't off any additional explanation unless you say how you calculate the time on the clocks based on the speed in a frame.
Agree. In my mind, "accumulate proper time" is associated with a notion of line element, and this one notion applies with full generality to SR or GR; whether the line element is:
d tau^2 = d t^2 - (dx^2 + dy^2 + d z^2)/ c^2 [which trivially gives (1/gamma) dt by rearrangement]
or the more general GR metrics, you have one method, one concept.
  • #32
But since proper time is the time displayed on any clock, saying "accumulate proper time" is no different than "explaining" the twin paradox by saying "look at the clocks of each twin at the start of the scenario and at the end of the scenario and that will tell you how much each one aged". It doesn't matter what you associate "accumulate proper time" with because it's the problem we're trying to explain, not the explanation of a different problem. I'm trying to at least associate the (dilated) times on the clocks with their speeds relative to a single frame of reference, not to each other.
  • #33
This is really good example of the inherent pitfalls (into which I've frequently slipped) of trying to intuitively express a technical concept. With all positive intent, we start with:
attempt 1) Twin that spends more (coordinate) time at higher speed in some frame ages less. Problem: example in post #24 shows this is wrong.
attempt 2) Twin with higher average speed in some frame ages less. Problem: false by same example
attempt 3) Twin that spends more time at higher gamma ages less. Problem: also false by same example. Twin A had higher gamma 80% of the time but ages more not less.
attempt 4) Twin with higher average gamma ages less. This can also be false. Consider twin A goes at speed with gamma of 3 the whole time. Consider twin B goes at speed with gamma of 1.5 half the time and gamma of 6 half the time. Twin B has higher average gamma (3.75) , but twin B ages more rather than less (assuming coordinate, e.g. t=6 over the paths, A ages 2, B ages 2.5).
attempt 5) Twin with lower average 1/gamma ages less. This is trivially true, but also just says "twin with lower average aging per coordinate time ages less", rather un-profound. We arrive, as the only true statement we can make, one twin ages less and here is how you calculate it.
This underscores my belief that all attempts at a simple rule (other than the formula itself) for which twin ages less run into trouble, even in SR.
  • #34
If acceleration is necessary for differential aging, how can twin's paradox be solved without involving general relativity? i.e solely on the basis of STR.
  • #35
Erase from your memory the false statement than SR cannot deal with acceleration.
  • #36
If so, then STR can't solve twin paradox? bcoz all the articles on internet say that it is acceleration which causes the the traveling twin to age less than the one who stayed on earth.
  • #37
SR can solve it, did solve it, right from when it was first presented by Einstein. Ignoring gravity (or topologically non-trivial universes), acceleration is necessary to have true twin 'paradox', but it is false to say the acceleration causes the age difference, or that the age difference is localized in any way to a period of acceleration.
  • #38
Then what causes the differential aging? How does STR solves the paradox. This may be very elementary question but I don't have solid understanding of relativity. Can you explain how STR solves paradox or can you give me good references where I can get my answer?
  • #40
ghwellsjr said:
[..] I'm trying to at least associate the (dilated) times on the clocks with their speeds relative to a single frame of reference, not to each other.
That is also how Einstein (1905) analysed the difference in clock readings and how Langevin (1911) discussed the difference in ages. I find that the clearest way of presenting it.
  • #41
- Done in post #22; it's not really considered paradoxical in SR.
Note also that Einstein already gave a correct but one-sided analysis in his 1905 paper:
section 4 of http://www.fourmilab.ch/etexts/einstein/specrel/www/
  • #42
And this I have no problem with at all. This is what I've been saying: pick a frame, accumulate dilated time (=proper time) along different paths. Compare. Result same no matter what frame you use for the analysis. Where I have a problem is attempts to state some other simple rule to predict or explain this - all such that I've ever seen I consider simply wrong.
  • #43
Since you asked, I will show you how STR solves the twin paradox. We'll use the scenario that PAllen presented in post #24:
PAllen said:
Consider that, while neither twin is ever inertial (due to continuous changes in direction), twin A is always moving at speed .4c in this chosen inertial frame. Suppose twin B is moving .1c for 80% of the coordinate time between separate and meet up, and at .99999c for 20% of the coordinate time.
And I'm going to use the process I described in post #16:
ghwellsjr said:
But this thread and all the discussion up to this point has been about the Twin Paradox where they start out together, separate, and come back together and I'm saying that if you agree to ignore gravity, then you can analyze the scenario in any single inertial Frame of Reference and the "time spent at a higher speed" is defined uniquely in that FoR and the "higher speed" is defined uniquely in that FoR and we're talking about the coordinate time of each body in that FoR and we apply Einstein's time dilation formula to convert coordinate time into proper time for each body and then we see how much proper time has accumulated for each body as it travels at different speeds according to the FoR for whatever coordinate time intervals from the time they separated until the time they reunite and we get the amount that each one aged and subtract them and we have the differential aging and no time disappeared or needs to be accounted for.
I know that's a mouthful but it's really very simple to analyze using Einstein's formula to get the proper time interval, τ, (tau, the time interval on a clock) as a function of its speed, β, (beta, the speed as a fraction of the speed of light), and the coordinate time interval, t, as specified in the Frame of Reference:
τ = t√(1-β2)
First we analyze Twin A who travels at 0.4c for 100% of the time:
τA = 100%√(1-0.42) = 100%√(1-0.16) = 100%√(0.84) = 100%(0.9165) = 91.65%
Now we analyze the first part of Twin B's trip at 0.1c for 80% of the time:
τB1 = 80%√(1-0.12) = 80%√(1-0.01) = 80%√(0.99) = 80%(0.995) = 79.6%
And the last part of Twin B's trip at 0.99999c for 20% of the time:
τB2 = 20%√(1-0.999992) = 20%√(1-0.99998) = 20%√(0.00002) = 20%(0.00447) = 0.09%
Finally we add the two parts of Twin B's trip to get the total time:
τB = τB1 + τB2 = 79.6% + 0.09% = 79.69%
So we see that Twin B with 79.69% of the coordinate time of the scenario ages less than Twin A with 91.65% of the coordinate time.
  • #44
Consider the previous post as attempt 6), the only one I presented.
I made the statement "time spent at a higher speed" specifically regarding a variant of the Twin Paradox to show that acceleration is not the cause of one twin aging less. In that variant, both twins experience exactly the same acceleration but one twin spends very little time at the higher speed and most of the time at the slower (rest) speed while the other one spends practically all of time at the higher speed.
Here's exactly what I said and I continue to stand by it:
ghwellsjr said:
I'm glad you mentioned both bodies experiencing acceleration because we can have another variant of the Twin Paradox in which both of them accelerate exactly the same except that one returns home immediately while the other one continues far away from home before matching the acceleration of his twin and returning home a lot later. This clearly shows that it's not the acceleration that causes the differential aging but rather time spent at the relatively higher speed that causes the differential aging.
  • · Replies 43 ·
  • · Replies 31 ·
  • · Replies 35 ·
  • · Replies 115 ·
9K
  • · Replies 31 ·
  • · Replies 70 ·
  • · Replies 36 ·
  • · Replies 24 ·
  • · Replies 25 ·
