How Does the Inverse of a Complex Number Affect Its Magnitude and Argument?
Taking the multiplicative inverse of a complex number inverts its magnitude, resulting in |z^{-1}| = 1/|z|, while the argument becomes its negative, expressed as arg(z^{-1}) = -arg(z). There is some debate about terminology, with one participant suggesting that "supplement" is incorrect in this context. The discussion also touches on the relationship between the reciprocal and the argument, with differing opinions on the correct expression for arg(z^{-1}). Overall, the key points focus on how the inverse affects both magnitude and argument. The conversation emphasizes the mathematical properties of complex numbers and invites further exploration of these concepts.
plexus0208
How does taking the multiplicative inverse (reciprocal) of a complex number change its magnitude and argument?
Mathematics news on Phys.org
A complex number z, when inverted, will have its magnitude also inverted, |z^{-1}| = \frac{1}{|z|} and its argument will become its supplement, arg(z^{-1}) = \pi - arg(z)
Why don't you try proving that?
This does not itself have anything to do with "differential equations" so I am moving it to "general mathematics".
I think "supplement" is wrong. The reciprocal of 1 is 1, but the supplement of 0 is not 0.
Hey,
I think that arg(z^-1) = - arg (z)
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
