How Does the Inverse Square Law Apply to Force of Attraction Between Charges?
  • Context: Undergrad
  • Thread starter Thread starter esvion
    Attraction Force
The discussion revolves around the application of the inverse square law to the force of attraction between electric charges, specifically in the context of Coulomb's law. Participants explore the mathematical formulation and implications of distance in the force equation, as well as comparisons to other physical principles.
  • One participant presents the formula for the force of attraction between two charges and questions the rationale behind the inverse square of the distance in the equation.
  • Another participant identifies Coulomb's law as an example of an inverse square law, suggesting that this is a common principle in physics.
  • A later reply discusses the application of the inverse square law to point or spherical sources, contrasting it with cases involving infinite lines or planes where the force behaves differently.
  • One participant introduces the concept of multipoles and suggests that exploring far field proportionalities in such systems can lead to interesting insights.
Participants do not reach a consensus on the implications of the inverse square law, as there are multiple perspectives on its application in different geometries and contexts.
The discussion includes references to specific cases where the inverse square law does not apply, such as infinite lines and planes, indicating that the applicability of the law may depend on the configuration of the charges involved.
This discussion may be of interest to those studying electrostatics, physics students exploring the principles of forces between charges, and individuals curious about the mathematical relationships in physical laws.
esvion
The force of attraction formula between two charges is
[tex]\frac{(k)(e1)(e2)}{r^2}[/tex]
How does the inverse of r2 fit into the equation? I understand the concept of how distance would need to be the inverse in the function, but why is the distance (r) in the inverse squared? Is this the same principle of why s^-2 is the acceleration formula and time is square in the inverse?
Thanks.
Coulomb's law is an example of an inverse square law, something quite common in physics. Read about it here: http://hyperphysics.phy-astr.gsu.edu/Hbase/Forces/isq.html"
I see! thanks!
Note that inverse square law is applies to point or spherical sources. For an infinitely (or very large) long line or cylinder, the ratio of force versus perpendicular distance to the line is 1/r. For an infinitely (or very large) plane, the force is constant (independent of distance).
Found the link for the other cases at the same site: electrical field
For the infinite line case, the field strenth is a function of charge "density" over the perpendicular distance "z" to the line ( ... / z).
For the infinite disc (plane) case, the limit as "R" approaches infinity, the [1 - z/sqrt(z^2 + R^2) ] term approaches [1 - 0], and the field strength is constant, independent of distance
Things get really cool when you start checking out far field proportionalities in systems of multipoles!
  • · Replies 19 ·
  • · Replies 44 ·
