How far can a person dive at 14' above the water?
  • Thread starter Thread starter apacheman15
    Water
To determine the launch angle and force needed for a dive from a 14-foot high platform to reach a horizontal distance of 14 feet, one must apply basic physics equations. First, calculate the time it takes for an object to free-fall from 14 feet, which can be derived from the equation of motion. Next, use this time to find the constant horizontal speed required to cover 14 feet in the same duration. The key is to achieve that horizontal speed while diving off the platform. Understanding these principles is crucial for calculating the necessary dive parameters.
apacheman15
Before I ask the question, let me say that nobody that I know (myself included) is going to partake in this potentially fatal stunt. Now then...here is the question? How can I figure out the launch angle and force of a dive needed to dive out 14' away from a sturdy platform that is also 14' high? I'm sure there is an equation but I don't have a clue how to figure it out.
You need to get a hold of those equations from Physics 101 about the relationship between distance traveled, time that it took and speed.
Also, about how long it takes to hit the ground when an object free-falls from a given height.
So, you first calculates to fall from 14'
Then, you take that time and calculate what constant speed you need to travel that distance horizontally during the same time...and all you need to do is start running and make sure you achieve that speed (horizonatly) as you leave the platform
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
