How Fast Can a 16-Inch Butterfly Valve Actuate?
The discussion focuses on the actuation speed of a 16-inch butterfly valve in different environments, specifically with clear water at 8 psi and air at 33 psi. It emphasizes that the opening and closing times depend on the actuator type and valve construction, with pneumatic actuators generally allowing for faster operation, potentially under one second. Electric actuators can also be used but are typically slower. The importance of consulting manufacturers and vendors for specific valve specifications and performance data is highlighted, as there is no standard time for actuation. Overall, achieving actuation within a 1 to 3 second range is feasible, particularly with the right pneumatic setup.
ENRG
Hello; just need approximations here. 16 inch buttterfly valve with separate environments on each side. side one: clear water at about 8psi; side two: air at about 33 psi; Consider both pneumatic and electric actuatiion under ideal conditions.What is the approximate fastest time to open and the fastest time to close? We are looking at quarter turn.
That depends on the actuator and valve/actuator construction. Get the spec sheet.
OK Thanks; I know this is a wide open question; first give me a good source online to help me get approximations; second, based on your knowledge of valves in general and more specifically actuators can I get an opening time within the 1 to 3 second range?
The manufacturer. Do you have a specific valve in mind? There are different types of actuators that can be used. On a 16in line, the actuator performances will vary greatly depending on loads. You can open a valve as quickly or slowly as you'd like, but it may not be reccommended.
When you say quarter turn you mean fully open, yes? Just wanted to make sure you mean that and not 25% "open".
Do a search, there are tons of vendors with different designs and different types of actuation. Contact vendors and ask them questions directly. There is no "average" time to open. Though I imagine on a 16 inch 150lb valve 3 seconds is pretty quick. Vendors will be your best bet.
Yes, butterfly valves can be made to open/close in something like 1 second or less even up to sizes in excess of 16" and pressures in excess of 1000 psi. These are always pneumatically actuated, not electrically though I don't know why they couldn't be in principal. In our industry, they're generally referred to as "slam valves", but they are simply butterfly valves made to open/close very quickly as a safeguard for equipment primarily. Jamesbury (Metso) makes these as do others.
http://www.jamesbury.com/public/brands/defaultframe.asp?type=Jamesbury
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
