How Fast is the Radius of a Circle Increasing When a Stone is Dropped in Water?
The problem involves a stone dropped into water, creating an expanding circle with a radius r. The perimeter of the circle is increasing at a rate of 3 m/s, and the discussion centers on determining the rate at which the radius is increasing when the radius is 2 m.
  • Mathematical reasoning, Assumption checking
  • Participants discuss the relationship between the circumference and the radius, using the formula for circumference to derive the rate of change of the radius. There is an exploration of different methods, including the area of the circle, to find the rate of increase.
Some participants have attempted calculations and expressed confusion regarding the arithmetic involved in determining the rate of change of the radius. There is acknowledgment of a potential error in interpreting the division in the formula, leading to different results. Guidance has been offered to check the arithmetic and how to input calculations correctly.
Participants are working under the constraints of a homework assignment, which may limit the information available and the methods they can use. There is a focus on ensuring the calculations align with the expected outcome of 0.48 m/s.
Schaus
A stone is dropped into some water and a circle of radius r is formed and slowly expands. The perimeter of the circle is increasing at 3 m/s. At the moment the radius is exactly 2m, what rate is the radius of the circle increasing?
Answer ## \frac {dr} {dt} = 0.48 m/s##
## C = 2πr##
## A = πr^2##
## \frac {dC} {dt} = 3 m/s##
## \frac {dr} {dt} = ?##
## C = 2πr##
Taking the derivative of circumference formula
## \frac {dC} {dt} = 2π \frac {dr} {dt}##
Subbing in my ## \frac {dC} {dt} = 3 m/s##
## 3 = 2π \frac {dr} {dt}##
Dividiving both sides by 2π gives me 4.71 m/s. I have also tried doing this with the Area of a circle formula but I still got 2.36 m/s which is no where near the 0.48 it is supposed to be. Any help would be greatly appreciated.
## C = 2πr##
## A = πr^2##
## C = 2πr##
Check your arithmetic calculating ##\frac 3 {2\pi}##.
That's weird. When I do 3/2pi it gives me 4.71 but if I do 3/6.28 I get my answer. Thanks for the help, I wish I had thought of trying that earlier!
That's because the calculator interprets it as ## \frac{3}{2}\pi##, ## \frac{3\pi}{2}##, or ##\frac{3}{2}(\frac{\pi}{1}) ## as opposed to ## \frac{3}{2\pi}##.
Next time, enter it into the calculator as 3/(2## \pi##)
  • · Replies 30 ·
  • · Replies 30 ·
