How Fast Must a Limo Travel Near Light Speed to Appear Shorter?
  • Thread starter Thread starter jwoosley
    Couple
To make a 9-meter stretch limo appear 5 meters long when traveling near light speed, the necessary speed can be calculated using the Lorentz contraction formula. The user initially calculated the speed as approximately 290,593,263 m/s but later corrected it to 249,443,825 m/s. To express this speed in terms of the speed of light (c), the user needs to divide by the speed of light, which is roughly 300,000,000 m/s. The resulting ratio will indicate the fraction of the speed of light the limo is traveling. Understanding these calculations is essential for solving the physics problem effectively.
jwoosley
hey everyone I'm new here. you all seem great at physics and my teacher gave us these problems and i have no clue as to how to do them! please help me it is due tonight!
1.Natalie designs stretch limo that is 9 m long but appears to be only 5.000m long when driven at speeds near the speed of light. How fast must Natalie be going to make the limo appear this long to Morgan who is watching the new stretch limo?
2.The net result of a hydrogen fusion reaction is that four hydrogen atoms combine to form a helium atom. The mass lost when rest energy is converted into radiation energy in the reaction is 3.250x10-29 kg. How much radiation energy does this reaction produce?
1. If your physics teacher gave you this problem then he/she certainly expects you to know the "Lorentz contraction" formula. Try looking that up first in your text or notes. If you honestly can't find, get back to us.
2. Once again, this is just a matter of apply a (well known!) formula that connects energy and mass. Look for it in your book or notes and get back to us.
ok i found the formula: final length = original length * sq root (1- (v2/c2)), so i plugged this in, solved for velocity and got 290593262.9, and it wants the answer in the unit "c", is that correct then?
correction the answer is 249443825, so how do i put this in "c"? thanks!
To place in terms of "c", divide your answer by the value for "c" itself, the speed of light, which is usually rounded to 300,000,000 m/s. The ratio is the fraction of the speed of light:
0.75c = three-quarters of the speed of light
0.5c = half of the speed of light
0.25c = quarter of the speed of light
etc.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
  • Poll Poll
