How fast must the rotor of a generator rotate?
To achieve a maximum induced emf of 55.0V in a generator, the rotor must rotate at approximately 262 revolutions per minute (rpm). The relationship between induced emf and rotor speed is established through the formula E = NBAω, where N, B, and A remain constant. Given that the maximum induced emf at 205 rpm is 43.0V, the same value of (NBA) can be used to calculate the new rotor speed for the desired emf. The calculations show that the rotor speed does not need to be converted to SI units for this problem. Thus, the required rotor speed for the specified emf increase is determined to be 262 rpm.
xswtxoj
The maximum indicued emf in a generator is 205rpm is 43.0V. How fast must the rotor of the generator rotate if it's to generate a maximum inducded emf of 55.0V?
E= NBAsinwt
205r/m*2 (Pi)/ 1rev81min/60s = 21.46rad/s
magnet field isn't given, so how can u solve this?
Check the formula for induced emf.
i did, but ur not given enough info to solve it, when u have E=-N ( magnetic flux)/ time or motion emf which is E= Blv
Formula for induces emf is E = NBAwsin(wt)
When a coil is moving in a magnetic field, E = -N( change in magnetic flux/time)
When a conductor is moving a magnetic field with a velocity v, E = Blv.
In your problem you hve to the first formula. At any instant th magnetic flux = NBA*cos(wt)
The eq for the induced emf is NBAwsin(wt). To max this eq out you have to realize the max value for the sin function is 1. Therefore, the max emf = NBAw. Since they give you what the max emf is for an w=205rev/min, you can simply solve for a value of (NBA). and use this same value for (NBA) in the eq 55V=(NBA)(w). You have to realize that the values for N, B, and A are not changing for this situation. You do not really have to change the w to SI units, or, 21.46 rad/sec. You can use the 205 rev/ min as the w to find a value for (NBA) and plug this into the eq 55V = (NBA)(w). Either way you get approx 262 rev/min.
9K
