How high should the bottle be placed above the needle?
  • Thread starter Thread starter huybinhs
    Needle
The discussion focuses on calculating the height at which a blood transfusion bottle should be placed above a needle to achieve a specific flow rate. The user attempts to apply the formula for flow rate (Q) and pressure difference (ΔP) but arrives at an incorrect height calculation. They seek guidance on correcting their approach, particularly in determining the pressure values and the final height formula. The conversation emphasizes the importance of accurate values for blood density and gravitational acceleration in the calculations. The user is looking for assistance to resolve their issue and achieve the correct height placement for the transfusion.
huybinhs
A patient is to be given a blood transfusion. The blood is to flow through a tube from a raised bottle to a needle inserted in the vein. The inside diameter of the 3.82 cm long needle is 0.393 mm and the required flow rate is 3.88 cm3 of blood per minute. How high should the bottle be placed above the needle? Obtain r and h from the Tables in the book. Assume the blood pressure is 19.3 torr above atmospheric pressure.
Q = [pi*r4*\DeltaP] / [8\eta*L]
=> \LambdaP = [(3.88*10^-6)/60s) * 8*4*10^-3*3.82*0.01] / pi*(0.1965)^4 = 16877 Pa
h = (P2 - Patm + \DeltaP ) / \rho * g
= 2573 Pa - 101325Pa + 16877Pa / (1.05*10^3 * 9.8) = wrong answer.
Please advise! Thanks!
Any ideas?
Any one?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
