How High Will the Bullet-Carrying Cart Climb the Ramp?
  • Thread starter Thread starter runningirl
    Momentum
The discussion centers on a physics problem involving a bullet embedded in a cart that rolls up a ramp. A 15 g bullet traveling at 150 m/s strikes a low-friction cart weighing 0.5 kg, and the goal is to determine the maximum height the cart will reach on a 30-degree incline. The initial calculations yield a velocity of 4.37 m/s for the cart after the collision, which is adjusted for the ramp's angle to 5.04 m/s. The height is then calculated using energy conservation principles, leading to confusion about the correct approach. Ultimately, the key equations involve momentum conservation and gravitational potential energy to find the maximum height reached by the cart.
runningirl
At a crime lab, they are experimenting measuring the speed of bullets. In it, a 15 g bullet is fired at 150 m/s into a wood block mounted on a low-friction cart (m=0.5kg). The bullet imbeds in the cart and the cart then rolls up a 30-degree ramp. Ignoring friction, predict the max height that the cart will rise to as it rolls up the lamp.
.015(150)+0=(.5+.015)vx
vx=4.37 ms
since it's a 30 degree angle.. the velocity of cart=4.37/cos(30)=5.04 m/s
x=(vf^2-vo^2)/2a
=(5.04^2-0)/2(9.8)
-1.2?
i don't know if this was correct.
Why not just say mgh=.5m(vx)^2
h = sqrt(4.37^2/20)
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
