What Causes Cloud-to-Ground Lightning Instead of Intra-Cloud Discharge?
  • Thread starter Thread starter Somnolence
    Lightning
Lightning operates similarly to a capacitor, with charge separation occurring in clouds due to convection and collisions of gas molecules. The lower part of the cloud becomes negatively charged while the upper part becomes positively charged, creating a strong electric field. Discharge to the ground occurs instead of intra-cloud discharge because the electric field between the cloud and ground can be stronger and the distance to the ground is often shorter than to the upper cloud regions. This makes it easier for the discharge to occur downward. Additionally, cloud-to-cloud discharges are also common, as evidenced by videos from the International Space Station.
Somnolence
From what I understand lightning works like a simple capacitor.
The convection brings up moist air that by collision with already condensed gas molecules, causes charge separation within the cloud. The bottom part of the cloud becomes negative while the top part becomes positive. The lower part of the cloud establishes a strong electric field between the upper and lower parts of the cloud as well as between the cloud and ground. Just like a capacitor. Turbulent air within the cloud makes it hard for charge from the bottom of the cloud to move up to the top of the cloud to equalize the charges.
Now to my question:
How can it be possible for a cloud to discharge to the ground rather than to discharge towards its upper sections witch I assume is by far much closer in space than the ground below the cloud.
Science news on Phys.org
Hi Somnolence
welcome to PF
because the charge separation between the cloud and ground can be larger than that between areas within the cloud. Also the distances involved are often much less between the base regions of the cloud and the ground
than to the upper regions of the cloud
eg. the cloud base may only be around 1,000 metres above the ground, often much less.
Whereas the distances from the base area to the upper cloud areas can easily be 8,000 - 15,000 metres
So its much easier to discharge across the shorter distance
cheers
Dave
In addition, there are frequent cloud-to-cloud discharges. There is a video of this happening as taken from the International Space Station floating aroundon YouTube. Try using the search terms "lightning space station".
cyklop said:
In addition, there are frequent cloud-to-cloud discharges. ...
yes, but that wasn't the question :wink:
I photo and video many CC discharges along with the CG's
Dave
Thanks for the replies! :D
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
