How Is the Constant C₂ Determined in a Heat Conduction Problem?
8 replies · 3K views
bugatti79
Folks, I am self studying through a heat conduction problem involving a 2nd order linear homogenous differential equation which has the solution of the form
##\theta (x)=C_1\cosh mx+ C_2\sinh mx## (1)
where ##m \equiv \sqrt \frac{c}{a}= \sqrt{\frac{\beta P}{k A}} ##
The constants are dertermined via the BC's ##\theta(0)=\theta_0## and
##[\theta_x+\frac{\beta}{k} \theta]_{x=l}=0## using ##sinh x =(e^x-e^{-x})/2## etc etc.
I can determine ##C_1=\theta(0)## but I don't know how ##C_2## is determined using the hyperbolic expression...
I attempted to rearrange ##\theta_x=-\frac{\beta}{k} \theta## from the BC given and equate that to the derivative of the general form of solution and then subsitute x=l in order to find C_2...ie
##\theta'(x)= m C_1 \sinh mx +C_2 \cosh mx## therefore at x=L
##\theta'(L)=m \theta_0 \sinh m L +C_2 \cosh m L=-\frac{\beta}{k} \theta##...?
Looks like the correct approach. But you dropped a factor of m in one of the terms when you took the derivative of theta(x). It shouldn't be hard to solve for C2.
That was a typo. I calculate ##C_2## to be
##\theta'(L)=m \theta_0 \sinh m L +m C_2 \cosh m L=-\frac{\beta}{k} \theta##
Thus ## \displaystyle C_2=\frac{-\frac{\beta}{k} \theta - \theta_0 m \sinh m L}{m \cosh m L}##
but the book gives it as
## \displaystyle C_2=-\theta_0[ \frac{\sinh mL+(\beta/mk) \cosh mL}{\cosh mL+(\beta/mk) \sinh mL}]##..?
Don't you mean [itex]\theta'(L)=m \theta_0 \sinh m L +m C_2 \cosh m L=-\frac{\beta}{k} \theta(L)[/itex] ? :wink:
Thanks for that typo. Still doesn't clarify how the book arrives at their answer..?
Well, what is [itex]\theta(L)[/itex]?:wink:
##\theta(L) = \theta_0 \cosh mL+C_2 \sinh mL## obtained from the first equation in post#1...therefor substituting in equation in the last post we get
[itex]\theta'(L)=m \theta_0 \sinh m L +m C_2 \cosh m L=-\frac{\beta}{k} (\theta_0 \cosh mL+C_2 \sinh mL)[/itex]...
not sure how you can get ##C_2## from this...thanks
Rearrange the terms so that the two terms with C2 are on the same side of the equation and the other terms on the other side. Then factor out the C2. For example if you had
a + b*C2 = d + e*C2
then
b*C2-e*C2 = d - a
C2*(b-e) = d-a
C2 = (d-a)/(b-e)
Very good guys...should have spotted that.
Thank you.
