How Is the Magnetic Field Calculated at Point P Near a Current-Carrying Wire?
The discussion revolves around calculating the magnetic field at a point near a long straight wire carrying a current, specifically using Ampere's Law. The original poster expresses confusion regarding the application of the law and the correctness of their derived expression for the magnetic field.
  • Participants discuss the application of Ampere's Law and its relevance to the problem. There are attempts to clarify the original poster's understanding of the law and the specific case of a long straight wire. Questions arise regarding the correctness of the original expression derived by the poster.
Some participants provide guidance on understanding Ampere's Law and its application, while others express uncertainty about the original poster's answer. There is no explicit consensus on the correctness of the answer, but the discussion is ongoing with various interpretations being explored.
There is mention of feedback from a professor regarding the original poster's answer, which may indicate a misunderstanding of the application of Ampere's Law versus a derived formula. The original poster's confidence in their answer contrasts with the feedback received.
amb0027
Studying for a test, and can't figure out what the real answer is for this problem.
There is a long vertical straight wire carrying a current Io upward. Use ampere's law to determine an expression for the magnetic field at point "P" a distance x from the long straight current carrying wire.
Ampere's law: B =[tex]\mu[/tex]oIo / 2[tex]\pi[/tex]r
Bp = [tex]\mu[/tex]oIo / 2[tex]\pi[/tex]x
Obviously not the right answer but I do not understand this stuff at all. Please explain? Thank you very much
Ampere's Law is not what you say it is.
Go to
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/amplaw.html
Read what Ampere's Law is, understand it, then click the link "Magnetic field from a long straight wire". Read and understand that. These links provide as good an explanation as any that you can get on the web.
I don't see the link "Magnetic field from a long straight wire" And i know what ampere's law is i just thought it broke down in this problem to what I stated. Trust me I've read plenty I just don't understand how to do this problem...
To me it seems that your answer is correct.
Near a very long wire, if you imagine a circular loop of radius x whose area is perpendicular to the wire, we should have
[tex]\oint_C \vec B \cdot d \vec l = \mu_0 I_{enc}[/tex]
Symmetry arguments tell us that the magnitude of the B field should be the same at all points on the loop, and the dot product should always give B dl. So we can pull the B out of the integral
[tex]B \oint dl = B * (2 \pi x) = \mu_0 I_{enc}[/tex]
Which is the same answer you have.
What makes you think that this answer is wrong?
Head of Physics Department at Auburn says its wrong haha.. but didn't give me the right answer, just marked through it.. he did give me one point, out of 10..
Perhaps you were marked down because you didn't actually use ampere's law.. you just used a special case formula derived from ampere's law.. I believe the answer is correct.
Maybe you should ask the professor who graded it why he marked it wrong.
