jetwaterluffy
- 227
How long does the boom from an explosion last? As in, how long does it make the sound for?
KyPhyTeach said:The energy that comes out of the explosion makes a shockwave. The shockwave passing you is the boom that you hear... same as a jet breaking the sound barrier. That is why you can not stand to close to an explosion besides the heat, the impact of the shockwave will kill you too. The shockwave is the expansion and compression of the air molecules. As for how long does it make the sound for. It makes the sound for an instant. It just takes some time for you to be able to hear it because of the speed of sound. That is why you can see the flash and then hear the boom if you are standing far enough away. Does this answer you question?
OK, how long does a nuke's explosion's boom last?Vladimirr said:"Explosion" doesn't really give you enough parameters to be able to tell.
Think about it - what's causing the sound? Is it due to something rapidly oxidizing/burning and vibrating against the air, like a firework? If so, how long does it burn? That's how long your sound is. Fast explosion? Quick, short sound. Slow burn? Longer sound.
It's possible for there to be multiple phases of an explosion, like a volcano. The "boom" will start making sound by the lava pushing its way through the ground (and then that sound traveling through the air to you), and then by its explosion through the air, and then even by impacting the surface when it lands.
Then you have to take into account your surroundings. If you're in a large room, or in a valley, the sound could continue to bounce around (echo) for a longer time. Also you have to take the medium into account. An explosion will make a boom of 0 seconds in a vacuum.
Like other folks have said here - sound is just caused by expansion and compression of the medium, in this case air. How long is it expanding and compressing? That's how long the sound is. It's like asking "how long is the sound when someone yells?" The answer is "as long as they're yelling for".
Sort of. I was hoping for a number, though. And why has everyone got an avatar now?Bobbywhy said:jetwaterluffy, from reading the responses so far I imagine that you have received a satisfactory answer to your original question. Here is my two cents worth from a passage taken from my memoirs as a civilian advisor in Vietnam during the war:
jetwaterluffy said:Sort of. I was hoping for a number, though. And why has everyone got an avatar now?
EDIT: oh, I see, april fools day.
jetwaterluffy said:How long does the boom from an explosion last? As in, how long does it make the sound for?
BadBrain said:Bobbywhy:
You're old enough to help me with this question.
Survivors of the Hiroshima blast from within the city recall no sound, but the most enormous flash of light, often described as a million photographic flash bulbs going off at once right in your face.
