How long does it take for the Magnetic Field to reach the detector?
When an electromagnet is activated, the magnetic field reaches a detector one light second away in one second, assuming the field propagates at the speed of light. However, some argue that a pure magnetic field does not transfer energy and thus may not exhibit a measurable propagation delay. The discussion highlights the relationship between electromagnetic waves and changes in magnetic fields, emphasizing that these changes propagate at light speed. Historical context is provided, noting that Maxwell's equations predicted the speed of electromagnetic waves, which corresponds to the speed of light. Overall, the connection between magnetic field changes and electromagnetic radiation is affirmed.
LitleBang
Suppose I had an electromagnet that would instantly go to full power when turned on (impossible) and at one light second away a detector capable of detecting the electromagnet. When I turn the electromagnet on how long does it take for the field to reach the detector?
One second.
Vanadium 50 said:
One second.
I am not sure about that because the velocity you are assuming is that of an EM wave. A pure magnetic field does not transfer energy, it just puts it into storage, so I don't think we can measure a propagation delay.
1 s is correct. You cannot switch on a “pure magnetic field”. That action generates an E field too.
Likes davenn
Please don't tell me what I am assuming. (Unless you are claiming ESP!) That's what you get using retarded potentials.
If you have a magnet and a compass, you most certainly measure the difference in time between energizing the magnet and the motion of the compass.
If you cycle the thing on and off a few hundred thousand times a second, it's a radio, isn't it? Probably not a good one.
Likes anorlunda
Yes. In fact a very similar thing happens in MRI. The coils used to transmit RF energy in MRI are actually not designed to transmit in the far field, but predominantly send energy to the local magnetic field, the near field. You can certainly detect far field signals, but as you say they are rather inefficient since most of the energy gets reflected back into the amplifier.
Interesting, a connection to the propagation of light. I can't post new ideas but I can post a question that leads to new ideas. How very very interesting.
The idea that electromagnetic field changes propagate at the speed of light isn't exactly new...
Likes davenn
As pointed out this is not a new idea. Electromagnetic waves (which is what light is composed of) carry information about changes in the electromagnetic field.
The history is interesting - here's the very oversimplified version:
That light propagated at a speed of about ##3\times{10}^8## meters/second was known since early in the 18th century (although not necessarily using those units, and ever more accurate measurements have been made since then).
During the 1860s James Maxwell formulated his equations describing the origin and behavior of electrical and magnetic fields, and discovered that these equations predict that changes in the electrical and magnetic fields would produce waves. He calculated the predicted speed of these waves... and the answer turned out to be ##3\times{10}^8## meters/second.
He then somewhat boldly suggested that these waves were light, that light was the electromagnetic radiation that his theory predicted. He was right.
So there is indeed a connection between the propagation of light and the propagation of your magnetic field changes - they are one and the same thing.
Likes Redbelly98, vanhees71 and Ibix
I have wondered how Maxwell must have felt when he first did that calculation and realized the connection.
