How long is this area in the air?
  • Thread starter Thread starter shawn2004
    Air Area
The discussion revolves around a request for assistance with physics problems involving circular motion and projectile motion. Key questions include calculating centripetal force for an object spun on a string, determining the maximum height and time in the air for an arrow shot at a specific angle and speed, finding tangential velocity given a rotational frequency and radius, and calculating angular acceleration from a change in angular velocity. The original poster expresses confusion about how to apply the relevant equations to solve these problems. Clarification and guidance in simplifying the questions are requested to facilitate understanding.
shawn2004
I understand what they are asking me in these problem but I don't know how plug these numbers in the equations.
If you could help me it would be wonderful thanks.
Fc if spun on a 2.5m string at 6 radians every 10 seconds?An arrow is shot at 20 m/s at an angle from the horizontal of 37 degree.what its maximum height? time in the air?Horitzontal range
tangential velociy if rotational frequency=0.75 Hz with a readius of 4.0m
Angular accerlation if change from 10rad/pie to stopped in 3.0 seconds?
Um, no offense but I don't really understand anything you just said, could you make it a bit more clear?
