How many revolutions does the merry go round make as it stops?
  • Thread starter Thread starter mags
    Revolutions
The problem involves a merry-go-round with a diameter of 5.0m that is initially rotating with a period of 4.0 seconds and comes to a stop over a duration of 20 seconds. Participants are discussing how to calculate the number of revolutions made during this deceleration phase.
  • Participants are attempting to calculate the initial angular speed and questioning how to determine the total number of revolutions as the merry-go-round stops. There are discussions about using linear kinematics and average speed in the context of rotational motion.
Some participants have provided calculations for initial angular speed and have noted the need to consider average speed for the total distance traveled in revolutions. There is an ongoing inquiry into the correct interpretation of the problem and the calculations involved.
There is a mention of confusion regarding the relationship between angular speed and the total number of revolutions, as well as the need to account for the average speed during deceleration. The final velocity is stated to be zero, as the merry-go-round stops.
mags
A 5.0m diameter merry go round is initially turning with a 4.0s period. It slows down and stops in 20 s. How many revolutions does the merry go round make as it stops?
w=v/r
v=2(pi)r/T
v=2(pi)2.5/4
=3.9 m/s
w=v/r
= 3.9/2.5
=1.56 rad/s
1.56 rad/s X (1rev/2(pi)rad)=2.48 rev
how is the answer 24.8? I don't understand...Please help
mags said:
v=2(pi)2.5/4
=3.9 m/s
w=v/r
= 3.9/2.5
=1.56 rad/s
This is the initial angular speed. The final angular speed is zero. What's the average speed as it slows down?
(Note that ω = 2π/T.)
i don't understand...
Final velocity (linear and angular) is zero because the problem says the merry-go-round stops. Try thinking of this in terms of linear kinematics, making the appropriate substitutions.
mags said:
w=v/r
= 3.9/2.5
=1.56 rad/s
You found the initial angular speed ω. Good.
What you did here was to convert from rad/s to revolutions per second; so that should be 2.48 rev/s.
To get the number of revolutions, you need to compute the angle traveled by the merry go round as it comes to rest. That's just the rotational analog to Distance = speed X time. Since the speed is not constant, you must use the average speed, not the initial speed. (The average speed is just half the initial speed.)
thanks a bunch...solved it!
  • · Replies 27 ·
