How many right triangles can you create with given coordinates?
Дьявол
Hello!
I have one question.
I have given 5 coordinates:
0 0
2 0
1 1
1 -1
3 -1
The question is how many right angles can I create with these coordinates?
I know one way out, but it is pretty complicated.
C52=5!/(2!*3!)=5*4*3!/(2!*3!)=10
And try every single combination (finding the sides of the triangles, there are 10 of them). Is there any simpler way?
Thanks in advance.
Regards.
Mathematics news on Phys.org
I'm not sure how you tested to see if the triangles are right, but the fastest way is to find the slope of the lines between each two points. Perpendicular lines have slopes which are negative reciprocals of each other.
you never made sure that the angles you'll get will be all right angles.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
