How many ways to cover this rectangle
  • Thread starter Thread starter sharpycasio
    Rectangle
The discussion focuses on finding the number of non-overlapping ways to cover a (2 x 10) rectangle using (1 x 1) and (1 x 3) rectangles. A participant suggests simplifying the problem by first calculating the arrangements for a (1 x 10) rectangle, which results in 28 ways. They then inquire about extrapolating this result to the (2 x 10) rectangle, speculating it could be 282 ways. Another participant agrees that 272 ways seems reasonable based on their calculations, emphasizing the importance of considering arrangements on both strips. The conversation highlights the complexity of combinatorial problems and the need for careful counting.
sharpycasio
In how many different non-overlapping ways can a (2 x 10) rectangle be covered by (1 x 1) and (1 x 3) rectangles.
I've never done any question like this. The only solution I can think of is a brute force method but I doubt that's the way it is intended to be solved. Any hints? Thanks.
Since the smaller rectangles can't overlap the larger (2 x 10) rectangle, you can simplify matters by looking at how you would cover a 1 x 10 rectangle with 1 x 1 squares and 1 x 3 rectangles.
That's true! Thanks. So if I did it correctly this what I got for a 1 x 10 rectangle. (For simplicity, rectangle refers to 1x3 and square refers to 1x1)0 rectangles and 10 squares: 1
1 rectangle and 7 squares: 8
2 rectangle and 4 squares: 15
3 rectangle and 1 squares: 4Total = 28 ways to cover a 1 x 10 rectangle.
How would I extrapolate from this to a 2 x 10 rectangle? Would it be 282? Thanks.
I haven't checked your figures, but for the 2 x 10 rectangle, 272 seems reasonable. For each of the 27 ways on one of the 1 x 10 strips, there are 27 different arrangements on the other strip.
I initially made a mistake (missed one arrangement). Right now I have 28. Thanks. (Previous post has been edited)
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
