How much energy radiates from Jupiter?
  • Thread starter Thread starter Ans
    Energy Jupiter
Jupiter radiates energy primarily from its internal heat rather than solar energy. Its surface temperature and energy absorption can be estimated using the Stefan-Boltzmann law, although Jupiter's non-black body characteristics complicate precise calculations. The planet receives solar energy, which can be scaled from Earth's solar intensity based on distance and albedo, but this method yields only rough estimates due to temperature variations across its surface. For more accurate data on Jupiter's energy balance, searching for "Jupiter energy balance" provides numerous scientific publications. Overall, while rough calculations can be made, precise measurements require deeper research into existing literature.
Ans
How much energy radiate Jupiter?
I tried to find it, but not found.
And how much energy it receive from Sun?
Astronomy news on Phys.org
Did you find its surface temperature and the Stefan-Boltzmann law? Jupiter is not a black body, but its (infrared) albedo should be listed somewhere as well.
You can take the solar intensity at Earth and scale it to the distance and size of Jupiter - again with the (visible) albedo to get the absorbed fraction.
I know it can be done. However, such result would not be precise, because some area have lower temperature, because of night or hurricanes, some area with higher temperatues. So I guess such approach can give only order of magnitude estimation.
Luminocity of Sun is described in many places, thermal balance of Earth too. I am sure Jupiter's thermal balance is also well described, but not know where it is described.
I did it before start post, and even calculated it in mind, without calculator :)
However, it is also very imprecise result.
If you are interested in more precise numbers, looking for "jupiter energy balance" at google leads to tons of publications.
Likes Ans
Thanks, seems as I used incorrect phrase for search
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
