How much H.P for a sugar cane crusher?
  • Context: High School
  • Thread starter Thread starter Bob02
    Sugar
Bob02
Hi there
I'm new to this form
Want to ask that , how much power in H.P will be sufficient to crush medium size (1 inch in dia) sugar cane stalk by the miniature sugar cane crusher for home use.The roller of the crusher will have a size of 6 inch in length and 3 inch in dia. the rollers will be of 304 s.s and in one piece, meaning the whole shaft and roller will be of one piece. that will be driven by the chain or may be directly connected to the main without using any chain or belt.
Any further idea about the design will also be welcomed especially about using chain, belt or not using them at all. the over all dimension can be any where to 12x10x10 where 12 is the height.
power is not the same thing as energy which is not the same thing as force. So the question doesn't make sense.
Bob02 said:
Hi there
Welcome to the PF.
As Curl points out, the amount of power input into performing your crushing task depends on several things, including how much and how fast you want to crush.
I'd guess that for home use, you're just doing one cane at a time, and can go slowly. I used Google Images to see what is commercially available, and got plenty of hits:
http://www.google.com/search?rlz=1T...&source=og&sa=N&hl=en&tab=wi&biw=1195&bih=726
There are even some hand-operated models shown in the results, so it can't take much power if you gear down the crank handle connection to the rollers. Have you seen units like these? Some say that you can use either the crank handle or electric power. If you can find specs on those models, that will tell you the approximate power you need from the motor.
thanks berkesman
I saw a model with 3 rollers, being driven by 1/4 HP motor and having chain too. I intend to use direct drive and 2 rollers so I guess 1/4 or even 1/8 HP should be fine. the motor will drive directly the main roller, both the shafts(roller+motor's) will be connected by the joint. I haven't seen any such thing else where that's why seeking advise.I guess 12 to 18 rpm should be safe and powerful enough to get the job done.
