How much lime juice to be used iso. citric acid?
The discussion centers on substituting lime juice for citric acid in mozzarella cheese making. The original recipe calls for 1 1/4 teaspoons of citric acid per gallon of milk, but the user is unable to find citric acid and seeks guidance on how much lime juice to use instead. It is noted that the acidity level is crucial for curd stretching; too little acidity results in no stretch, while too much can ruin the curds. Participants emphasize that the acidity of lime juice varies based on factors like fruit ripeness, making precise conversions challenging. Suggestions include using general ranges for lime juice and considering the pH of the milk, which can significantly affect the outcome. The conversation also touches on the complexities of adjusting milk pH with citric acid, highlighting the importance of measuring tools like pH meters or strips for accurate results.
yibyib
How much lime juice to be used iso. citric acid??
Dear all,
I'm now trying to make mozzarella cheese. The recipe wrote that use 1 1/4 tsp. for a gallon of milk (I think US gallon). The problem is I can't find citric acid right now. If I want to try lime juice instead of it, how much of lime juice do I have to use for 1 1/4 tsp. of citric acid??
FYI, acidity is what allows the curds to stretch: no acidity, no stretch but, too much acidity make curds become hopeless mess .
Thanks all.
Chemistry news on Phys.org
Values that you can find (or that anyone can give you here) won't be accurate, as amount of citric acid present depends on the ripeness of the fruit and on many other factors. Best values should be given as "usually something between x and y".
If you can assume the value of the unknown parameters, can you show me how to solve the problem?
Or another question, If I want to reduce pH of 1 Litre of milk from X.x(I don't know pH of milk) to be around 5.6 by using citric acid (powder type) -- How many grams of citric acid do I have to use?? You can assume any parameter you want. Feel free to let me know things. Very thanks to you.:redface:
What do you know about the concentration and how it is related to volume of solution and amount of dissolved substance? Try to read concentration lectures, basically you will find everything you may need there - but feel free to ask if something is not clear.
There is no simple answer to that question - best approach is to use pH meter or pH strips. A lot depends on the initial pH (which can be already around 5.6 that you ask for).
Thank you Borek. I'll work it out and I may ask you later.:redface:
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
13K
21K
14K
