How Much Power Is Lost Due to Resistive Heating in a High-Voltage Line?
A 750-MW power plant transmits power through a 475,000 V high-voltage line with a resistance of 0.65 Ω. The discussion revolves around calculating the percentage of power lost due to resistive heating using the formula P(loss) = I²R. The user initially struggled to find the current (I) but successfully used P = VI to determine it, leading to the calculation of power loss. Ultimately, the user was able to compute the power loss and express gratitude for the assistance received. The conversation highlights the importance of understanding resistive heating in high-voltage power transmission.
plexxity
A 750-MW power plant sends its power out on a 475,000 V high-voltage line. If the total resistance of the line is 0.65 Ω, what percentage of the power is lost due to resistive heating?
i have NO idea but maybe...
P(loss)=I²R
P(loss)=^v²/R
P=V(V/R)
P=VI
V=IR
P=E/t
Guess i don't know where to start
Use P=VI to find I.
thanks i found I then i was able to get the Ploss=I^2(R)
got the answer Thanks!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
