How Much Work Is Done on a Mass by a Time-Varying Force?
The discussion revolves around calculating the work done on a 10.0 kg mass by a time-varying horizontal force, F(t) = (1.00 t + 0.250 t^2) Newtons, applied over 5 seconds. The initial attempt at integration yielded a work value of 22.917, but the correct answer is 26.3. Participants clarify that the integration should be performed with respect to displacement, not time, leading to the realization that impulse can be used to find work. The conversation emphasizes that the derived formula is specific to the initial condition of the mass being at rest. The final conclusion highlights the importance of understanding the relationship between force, displacement, and work in this context.
XwakeriderX
A time-varying horizontal force is given by,
The force is applied from 0 to 5.00 seconds on a 10.0 kg mass which is initially at rest but is allowed to slide freely with only this one horizontal force acting on it. How much work is done on the mass by force F during the 5 seconds?
W=Integral (from Xi to Xf) Fxdx
W=(t^2)/2 + (t^3)/12 from 0 to 5
W=22.917
That is what i got from integrating.. But the answer is 26.3
Hi XwakeriderX! :smile:
(have an integral: ∫ and try using the X2 and X2 icons just above the Reply box :wink:)
No, that's ∫ F dt, and (as you say) you need ∫ F dx …
try again :smile:
Ah okay i got it! i used impulse then apllied W=Pf^2/2M
remember of course that this isn't a general formula, it works here only because vi = 0 …
generally ∆W = ((vi + P)2 - vi2)/2m = (P2 + 2viP)/2m :wink:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
