B How slow can Gedanken experiments be theoretically?
  • B
  • Thread starter Thread starter NTHstars
    Experiments
NTHstars
New techniques are slowing down light. Spacial separation is used in Wheeler’s delayed-choice Gedanken experiments to increase the time between aspects of the experiments. Potentially, could new techniques slow the experiments down much further, and, if so, within reason how much slower could the experiments be? Are there hypothetical strategies that could extend such experiments into seconds or longer?
Given that a "Gedanken experiment" is just a fancy word for a thought experiment, I imagine they can be about as slow as you'd like them to be.
Likes DaveC426913
Agree w/ Dewgale. NTHstars, are you asking about thought experiments, or about real experiments?
The real experiments, thanks!
Actual delayed-choice experiments have been done. You can keep the interesting steps without causal connection and it still works. You don't need to slow light for that.
I guess another way to ask the question is...theoretically, is it feasible to slow the experiment down drastically by using time instead of space? I don't mean in some sci-fi way, I mean by purposefully "holding up" the light by perhaps having it bounce off mirrors (or whatever) for a set duration of time before it was allowed to "complete" the experiment. What I'm looking for is...from the time the light first enters the experiment, until the experiment is complete and the total results are known, could you theoretically purposefully drastically "slow" or delay the passage of the photons to the extend the duration of the experiment?
You can add delays for the light as much as you want, it doesn't matter. It just makes the experiment more challenging in terms of alignment of the components and so on.
That doesn't slow the light, it just makes it go a longer distance which of course increases the travel time. This is a common experimental technique (although it's generally more practical to do "whatever" using optical fiber instead of mirrors - easier to route around obstacles, less attenuation).
If you tried to set up an experiment where one set so results (let's say an interference pattern - or not) was recorded and then you tried to force the entangled partners to do something uncorrelated, is there any thinking on what would happen? I can think of a few ways that nature might get out of it (*), but I wonder what the best theory is at present?
(*) For example, if we definitely have a double-slit interference pattern and we then look at the entangled partners - assuming the photons are confined in some way and so the second measurement apparatus is not too far away - then perhaps too much uncertainty in each photons path has built up - or too many get absorbed by the apparatus and are lost to the experiment. So that the more certain the interfence pattern, then the more photons that go missing from the second half of the experiment?
Quantum mechanics. The Wikipedia article describes the experiment in more detail.
You can't do that (unless the entanglement is in something irrelevant).
