- 50,361
- 26,404
PeterDonis said:The result of that calculation (which I'll let the OP discover for himself) does not actually give a tensile strength that violates the known laws of physics--it still implies a sound speed in the material that is less than the speed of light.
Actually, I should clarify this. A better way of stating the limit on tensile strength for this problem is that the tensile strength in pressure units, or equivalently energy density units (which are the usual units for tensile strength) must be less than ##1/3## of the energy density of the material. This allows one to explore a range of parameters for the chain, balancing the energy density against the cross sectional area (basically, the smaller you want the cross sectional area to be, the greater the energy density has to be to stay within the limit, since smaller cross sectional area means larger tensile strength required for a given force).
Given the above, there is a range of parameters for the chain that allow a tensile strength that does not violate the known laws of physics. But those parameters are pretty extreme.
